Isn't a dual output coil how some racers ran 2 spark plugs per cyl in the early days?(mainly 2 stroke racing I believe)
l8r
Yep, sure is...that's one of the mods I used to do to the Suzy's we sold for Enduro racing. I put a CB750 or CB160/175 coil on them, and ran it from the magneto, because the Suzy's had the extra hole for a compression release (or you could use a short-reach plug). It made an adequate spark, but a mag-type coil was better (and 3 times the cost, because it was a "racing" part.
Sometimes, we put a colder plug in the short-reach hole instead, so the riders could run FWO on the hiway for that leg of the Enduro without overheating the cylinder head. The rider would just swap the wire before hitting the road leg (single-wire coil setup, though).
