Author Topic: battery cables  (Read 1167 times)
Offline Butchbaby
  • 1977 CB550F
battery cables
« on: February 19, 2008, 06:22:24 PM »
What gauge cables are on the 77 cb550f. I need to rep;ace mine and don't know what gauge I should use. I would appreciate the help/
Bob550four
Re: battery cables
« Reply #1 on: February 19, 2008, 07:35:13 PM »
I dont know what gauge they are, but I adapted a cable from a newer sportbike to fit.   if you can find battery cable for a modern bike that fits, just get a length of it, and some ends to hook it up.
Offline Steve F
Re: battery cables
« Reply #2 on: February 20, 2008, 03:15:14 AM »
Don't know what the wire gauge is, but I've made cables from welding cable.  I was able to get some at the local hardware store by the foot.  I like the welding cable since it has a high wire count making them really flexible.  I fashioned some cable ends using copper tubing, I believe 5/16", by flattening one end of a 2" piece and then drilling holes for the battery terminals and the end bolts. I then soldered them on using rosin flux, solder, and a torch.  Then I used heavy-duty heat shrink tubing to finish them.  It's been almost 10 years and they still look and work great.
Offline dusterdude
Re: battery cables
« Reply #3 on: February 20, 2008, 11:06:23 AM »
i would think you can use 6 gauge at the least
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Bob Wessner
  • "Carbs Suck!"
Re: battery cables
« Reply #4 on: February 20, 2008, 11:28:28 AM »
