Author Topic: Pictures with likely dangerous lower kit  (Read 3714 times)
Offline Sweep
  • Just remember there are no stupid questions, just some idiot asking them.
« on: February 20, 2008, 08:34:28 AM »
Someone here requested these so here they are.  I'm either going to replace these with the better ones I just bought on ebay or I will try some lower progressive shocks I bought for my Sportster and never used.  These at least show the stance.
What I really like is what it allowed me to do with my clipons, mounting them above the trees.  The last two pics are the detail of the blocks and how they look when I put the bike on the center stand (or a bad bump in the road!).
'76 cb750K Wiseco 836|ape crank/head|Carillos|CR29s|Dyna 2k|Kerker
'74 Norton Commando Fastback w/belt and bells
Re: Pictures with likely dangerous lower kit
« Reply #1 on: February 20, 2008, 08:45:52 AM »
The ones I had way back were similar to those except they bolted down at the back.
Looks like you could drill another hole at the front and be able to add a tab to the back and be safe.
I think due to the chopper craze they are moving these to far back and not bolting them down which is not good.
The others you bought would work if you added a part to  bolt it down, and boxed it in by using flat bar to tie the 2 sides together..
 Looks like there is a good need for a decent lowering kit...
« Reply #2 on: February 20, 2008, 08:49:59 AM »
I'd get rid of those things for sure.
Offline 333
  • Time for change
« Reply #3 on: February 20, 2008, 08:56:38 AM »
What about tightening the swingarm side tight enough so it doesn't move?
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline Patrick
« Reply #4 on: February 20, 2008, 09:00:51 AM »
I'm not sure I totally understand the point of having rear shocks if they aren't securely fastened to the frame.
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline dusterdude
« Reply #5 on: February 20, 2008, 09:02:27 AM »
those appear to be installed backwards.i have a set lowering blocks on my sportster havent any issues at all.i dont know how they mount compared to our bikes tho.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
« Reply #6 on: February 20, 2008, 09:03:51 AM »
That wont do it, it is bolted into a rubber mount, but I can see how folks THINK that may solve it.. has to be bolted at the rear or welded.
Seriously, mine were a bit shorter bolted to the axle opening bolt at the back and never moved.. never gave any indication they were there while riding. These ones are moved too far back.
The other thing you can do is machine a new tube for the front and lengthen the swingarm
Offline Patrick
« Reply #7 on: February 20, 2008, 09:16:23 AM »
These are the lowering blocks I have on my very dirty and dusty 750. They bolt at the back and don't move.
http://i130.photobucket.com/albums/p247/wordguy11111/HPIM2236.jpg
Sorry, I haven't worked out the intricacies of posting pictures directly. Just links.
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline ekim98
« Reply #8 on: February 20, 2008, 09:30:15 AM »
That would work,but seems like a lot of work just to lower the bike a little. Shorter shocks would surely be cheaper and just as effective tho, and not cause possible handleing problems I would think. I took the lower blocks like those off mine when I got it, but for the average guy just motoring around they may not be that bad. But then most people here don't just putt around so !!!
Patriot Guard Rider - KY. Ride with Respect
78 750k  cafe bike sort of
67 305  Superhawk (working project)
« Reply #9 on: February 20, 2008, 09:42:41 AM »
Patrick, That is what I meant and they work well. Yours appears to be stamped. The differende is the Patrick type is not to radical a change in angle and bolted down.
The others shown are not.
Swingarm extesion.. some folks have a buddy with a lathe, thier own welder... and would rather spend an afternoon and 30 bux than spend 200 on shocks.. some like making parts for their bikes..
Sweep, see if you can get a bushing or nut weded to the back of the mount..may need grinding..then run the bolt up from underneath, then weld it to the block.. ;D
Offline Patrick
« Reply #10 on: February 20, 2008, 09:48:45 AM »
I never should have taken that closeup of my back axle. Wow, is it filthy. Anybody got a clean, rust free back axle?.....
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
« Reply #11 on: February 20, 2008, 09:52:20 AM »
Never mind the axle.. when are you going to bolt the sprocket to the carrier?? :o :o :o
Offline Patrick
« Reply #12 on: February 20, 2008, 09:59:41 AM »
I like my sprockets free spinning......
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline merc2dogs
« Reply #13 on: February 20, 2008, 10:05:29 AM »
 That's pretty much what I thought would happen when I saw them in the other thread.
 I'd prefer going with short shocks. Or spend the time doing the job in the garage.
 Possible fix for that pair would be a 'U' strap that fits around/through the 'new' shock mount, wraps under and is fastened to the swingarm with the clamp bolt.
  I've looked into getting a pair of the lowering blocks because I have short legs, but always talk myself out of it.  made a new seat so I can stand flat footed now and don't worry about it anymore.
 As for 'rust' in pics, for some reason every time I take a picture of my bike, it looks rusty, crawl  around and look where the rust is in the pic, and I can't see it.
 I've got a picture of my bikes rear tire, and in the pic the swingarm, axle and brake lever all look rusty, but except for the bolt on the brake lever, there is none visible to the eye.
Ken.
Offline Patrick
« Reply #14 on: February 20, 2008, 10:09:46 AM »
And you can't tell from the picture, but the frame is freshly painted and looks perfect (if dusty) to the naked eye, and those lowering block are freshly powder coated and have no blemishes.
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline Sweep
« Reply #15 on: February 20, 2008, 10:13:45 AM »
It won't happen without messing up the mount.  Not worth it.
There ya go Patrick.  That's where I'm headed.
Offline chrislib
« Reply #16 on: February 20, 2008, 02:38:22 PM »
Aside from an originality/"proper" standpoint, why not just shorten the origianl ones? I did mine (wich are/were fairly rusty/crusty so don`t feel too bad about O.E. stuff gettin hacked) and it was pretty easy. Took them down to just about 11 inches. I disassembled the, re-threaded and cut the shock shaft and took about 1 3/4 coils out of the spring. I should add that altho it looks killer I havent ridden it yet as there are many other things to be done before it`s rideable so I can`t give ya a real world ride/handling critique of the mod.
Chris...closet Idlefiddler
#1975
1973 CB750K...CANDY BACCHUS OLIVE
fuzzybutt
« Reply #17 on: February 20, 2008, 06:52:51 PM »
i'm going to be doing just that to a set of cb1100f piggyback shocks, just making em the same length of sohc 750 shocks
