Author Topic: Dunstall clip ons from a CB750 on a CB500  (Read 3283 times)
Offline canttuckmyshirt
72 CB500, Abe Henry wheels
77 CB550, resto-mod
04 S2000, LS1 V8
Offline Godffery
  • Godffery's Garage
Re: Dunstall clip ons from a CB750 on a CB500
« Reply #1 on: February 21, 2008, 08:57:40 AM »
   Yes, they both have 35mm fork tubes.
But these are among the best that I've found :
http://www.whaccessories.com/TelefixProfi.jpg whaccessories.com
http://www.mgcycle.com/410181135w.JPG mgcycle.com
http://www.motorcycle-parts.com.au/Race_Bars_Axe_105.jpg motorcycle-parts.com
Godffery
http://tinyurl.com/yoelqb
Superbiker_uk
« Reply #2 on: February 21, 2008, 10:00:27 AM »
The Dunstall part numbers for these are different. CB750 clipons are 1017 and the ones listed for the CB500 in the catalogues I have are 1019. Also they do not use the standard fork tube top nuts on the ones for the CB500. Instead thay had a smaller hole and were supplied with specially made alloy fork tube top nuts. This is likely due to the pinch bolt position on the CB500 top yoke compared with the top yoke of the CB750. I would suggest that they are not interchageable between models - hence the model specific designs originally produced. There was also a set specially made for the CB250/350 part number 1022.
« Reply #3 on: February 21, 2008, 11:01:17 AM »
I guess thats a deal breaker then :(
I have aftermarket aluminum top nuts that are drilled for air-assist. They are much larger than stock.
I'll just keep looking for nice clip ons. I want ones that clip below the triples but rise even or above them.. I don't want to lower my front end to put them on top..
77 CB550, resto-mod
04 S2000, LS1 V8
Offline LoopsAndLogic
  • Dang IT!!!
« Reply #4 on: February 21, 2008, 01:07:42 PM »
You might want to check out the clipons that are from a 84-86' Honda VF500 interceptor.
I shimmed them on my 400f to work and they feel great! Plus, they look stellar!!
And I believe they are 35mm, cause the 400f's forks are 33mm's.
Good luck
LL
My rides:
75' 76' Honda CB400F Super Sports
86' Honda XR600R for Street Madness
84' Honda Interceptor VF500
Past Rides:
80' Honda CX500C Fully Dressed
81' Honda CB650C very nice!
83' Kawasaki KZ550 A3
78' Hondamatic 400 Hawk
80' 81' 82' Honda GL500 Silverwing Insterstate
