**putting this project on hold because of some new projects-follow the link to see them!**
http://forums.sohc4.net/index.php?topic=31751.0 So I'm all about the CB SOHC motor but I was able to pick up a CX500 for just 125 bucks and figured, what the heck, lets play! I have a miller welder and a cutting torch and my trusty grinder so I decided to burn some metal and see what happens. This is great practice for future projects and sharing some pics seemed like a good thing to do. This forum has really inspired me to just get out in the garage and build something, Anything! I hope you enjoy!
As usual I started right in with out grabbing the camera, but i was able to "simulate" the original tank.
I extended the tank 3 inches following the same lines as the tank.
doing this made the end of the tank way to wide, so I had to section out an inch and a quarter wide piece.
It was about right here when I ran out of gas for my welder and had to stop. So I spent some time grinding down my not so pretty welds. I will of course go over everything and use some kind of in-tank liner to prevent leaks.
and lastely, a quick mock up of the extended tank on the frame.
That's it for now, but I will update it as I progress.
Later~
