Author Topic: land speed record bike  (Read 69452 times)
Offline DarkRider
Re: land speed record bike
« Reply #175 on: December 10, 2008, 07:36:20 pm »
ever stop to think that running with that ballast might give you the traction you need with the juice?
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline scunny
  • don't call me expert
« Reply #176 on: December 10, 2008, 08:39:54 pm »
it's his juice I'm worried about
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline DarkRider
« Reply #177 on: December 11, 2008, 02:58:04 pm »
What? you think it may have gone stale with age? lol
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
« Reply #178 on: December 11, 2008, 03:42:14 pm »
I have some really nice fans in you lot :D :D :D :D :D :D
Sam. ;)
Rocking-M
« Reply #179 on: December 11, 2008, 03:50:48 pm »
Sam. ;)
now Sam, you know if we didn't like you we wouldn't pick.  ;) ;) ;) ;)
« Reply #180 on: December 15, 2008, 02:53:26 pm »
Sam. ;D
Offline scunny
« Reply #181 on: December 15, 2008, 02:56:12 pm »
so where to ignition wise Sam ?
            VTR1000F3
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
« Reply #182 on: December 15, 2008, 03:06:27 pm »
Spoke to Trev last week, probably soon after Christmas.
Things might be changing for me at work, I'll be working the same hours as Chris so we should be able to organise things easier.
Sam. ;)
Offline KeithTurk
« Reply #183 on: December 15, 2008, 09:11:15 pm »
Hey Sam... did your spark plugs confirm it going rich when you hit the Nitrous button?
I'll bet your ignition is fine... but there's something wrong with the Fuel delivery system with the Nitrous... how are you injecting it? what's the Fuel pressure when the button is down? and are you decreasing the timing prior to the run since you don't have a retard mechanism?
I've run 10lbs in a single pass several times over the years... and Trust me the one thing I've learned is it's absolutely the most unforgiving HP in the world... but when it's right... it's brutally cheap and totally addicting...
K
« Reply #184 on: December 15, 2008, 09:51:36 pm »
+1. I saw Richard Hammond on "Top Gear" with a clapped out 1970's Jag XJ6 crap on a Ferrari, Lamborghini and Porsche turbo when the boys fitted it with a $1000.00 NOS injection installation. That old boat anchor of an engine was making in excess of 500 BHP, farking incredible! ;D
« Reply #185 on: December 15, 2008, 09:56:48 pm »
best of luck Sam , although you won't need it  ;)
i've seen the episode, it was pretty crazy  ;D
« Reply #186 on: December 15, 2008, 09:59:56 pm »
K
will get back tonight Keith, not got time now as I'm due a shift change in a few mins.
Sam. ;)
Offline KeithTurk
« Reply #187 on: December 16, 2008, 06:02:39 am »
before I make a pass with Nitrous we do three tests
Check the ignition for retard
Flowing fuel pressure
Nitrous solenoid flow...
Takes a few minutes but you won't blow stuff up quite as often if you do that...
K
Offline Soos
« Reply #188 on: December 16, 2008, 06:46:48 am »
Hey Sam,
sent a PM...
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
« Reply #189 on: December 16, 2008, 04:01:50 pm »
Hi Guys, I've a little more time now ;D ;D ;D I'd be lost without work as I'm not on line at home. ::)
Keith, I'm new to nitrous and don't know a great lot about the finer points.
I had the system fitted by the manufacturer with a 5bhp shot (12.5% power increase)
I have been having issues with the jetting all season prior to fitting the nitrous and am down to a very small main jet that others running the same motor would never get down to irrespective of weather or altitude.
After the nitrous guy told me that in his opinion the spark was not strong enough to burn extra fuel charge, I got to wondering if that was the reason I am jetting way lower than others using the same motor.
If I have a poor spark and run the same jetting that others are using with good results on the same day it would show up as rich on my plug readings as the spark isn't burning the amount of fuel that I am putting in.
When I had the nitrous fitted it worked static (I even tried it myself, it was OK) but would not work under load, the more I used it the slower my times went over the quarter.
If I get to the stage where I start upping the BHP shots I'll be needing an ignition system that will retard on comand when the nitrous is fired, this is the system that will be fitted after Christmas and the whole thing will be set up on the dyno.
The system is a one off type developed buy the Nitrous system manufacturer and Boyer Bransen.
Sam. ;)
« Reply #190 on: December 16, 2008, 04:13:38 pm »
Hey Sam,
sent a PM...
l8r
Thanks Soos.
Sam. ;)
Offline KeithTurk
« Reply #191 on: December 16, 2008, 05:00:57 pm »
Okay quickie Nitrous class... should we start a new thread or keep it here?
Basically Nitrous has more oxygen per volume then normal oxygen.... like 33% vs 23 % or something like that...  so when you inject it into the air stream it gives you the ability to add more Fuel... for a given volume of air... it also has the innate ability to decrease the inlet air temp significantly...
Because the intake charge has more O2 and more Fuel... it has the ability to produce more HP...    bout that simple...
What is really cool about Nitrous is that it increases the combustability of the fuel charge by giving it so much more O2 to burn with... so if there is an issue with knotty type pistons or heads that have flame probagation issues... Nitrous fixes the snot out of it... ( think BIG compression in the 14-1 range )  the only way you get the high compression is to fill every nook and cranny with Piston or Heads...
Hmmm  Because the fuel/air charge burns faster you want to wait just a bit later to fire it off... hence the requirement to run a retarding device...    One of the things you might want to think about is retarding the timing a few degree's up front then you won't need a retard device...
Oh as far the spark is concerned... grab one of those spark plug testers ( allows you to move the spark plug away from the ground )...  it simply doesn't take much spark.... and Nitrous rarely blows out the spark like a Supercharger... ( I've had that trouble in the past too )
Keith
« Reply #192 on: December 16, 2008, 05:08:24 pm »
Keep us posted Sammy, I'm (seriously) looking at a NOS kit for my twin engined bicycle (yes, I am still being serious) Land Speed Record attempt at Lake Gairdner in South Australia in March '09.
I've found some cheap NOS kits on EBay that guys with regular motorised bycycles have used, with good results, so I'm tempted to install a kit for when my pilot (not me, I'm too heavy) hits terminal velocity on the salt. Cheers, Terry. ;D
« Reply #193 on: December 16, 2008, 05:33:44 pm »
He'll need strong arms Terry. ;D ;D ;D ;D ;D ;D
Sam. ;)
« Reply #194 on: December 16, 2008, 08:38:29 pm »
Keith, whats the reasoning with the 5lt minimum tank size in the rules for Modified Production ?
My tank is only 1lt and the bike runs all day on it. ;D ;D
Would I have to have a new tank made.
Sam. ;)
Offline KeithTurk
« Reply #195 on: December 17, 2008, 02:26:11 am »
Lots of the rules are written for all size bikes and some of them have origins from the older days like the Harley's dual tanks...
So I'd suspect that is simply a hold over from then...  When I write the motorcycle rules for the ECTA it's better for our competitors to have a smooth flow between Maxton and Bonneville... so we keep mostly the same rules...
K
« Reply #196 on: December 17, 2008, 11:04:40 am »
I take it that's a yes then, I need a great big 5lt tank on my tiny bike. :D :D :D :D :D
Sam. ;)
Offline scunny
« Reply #197 on: December 17, 2008, 06:00:07 pm »
get a bigger bike then Sam  ;D
            VTR1000F3
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
Offline tsflstb
« Reply #198 on: December 18, 2008, 10:54:28 pm »
Sorry for a quick aside...what do you think of this here RS Sam?  Was 1995 the year when they were updated?
http://houston.craigslist.org/mcy/929142186.html
The guy's been trying to sell it for a couple of months now - there's not much of a market for these here.  I'm sure he's losing his shirt at that price.
I've heard you go through a crankshaft every 1k miles - are they getting hard to find?
« Reply #199 on: December 23, 2008, 05:17:24 pm »
Hi Steph, It's a good price for what you are getting with the leathers thrown in.
There again, you don't need leathers, do you ? ;D ;D
The RS does need a crank every 1K miles but they are not over expencive.
It's the years before this one that parts are hard to find for.
Sam. ;)
