Author Topic: land speed record bike  (Read 83658 times)
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
Re: land speed record bike
« Reply #300 on: March 13, 2009, 02:17:40 PM »
Are you using a rev limiter as well?
Glad to hear everything is going well so far!
We wanna see those dyno numbers! (or at least I do :) )
L8r
Count me in for the post. That should some fun to look at.
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
« Reply #301 on: March 16, 2009, 04:41:22 PM »
Get it on the M6 Sam & give it a blast  ;D, cheers Mick.
To many twists and bendy bits Mick, ya know me......drag racer ;D ;D ;D ;D ;D ;D ;D
Sam. ;)
« Reply #302 on: March 16, 2009, 04:43:17 PM »
L8r
It's a two stroke Soos, no real need, no valves to go crunch ;D ;D ;D ;D ;D
Sam. ;)
« Reply #303 on: March 16, 2009, 04:48:16 PM »
Had an email waiting for me tonight, bikes all back together and running.
The only problem is, the stock Honda rev counter was coulped into the ignition box that I no longer have so he's going to try to figure somthing or it's £££££££££ around 130 for a Scitsu jobby.
We should be on the dyno Saturday.
Sam. ;)
Offline volkswagendan
  • im a bit off the charts. sorry.
« Reply #304 on: March 16, 2009, 06:35:09 PM »
looking forward to the dyno results.
don't take me too seriously.
« Reply #305 on: March 16, 2009, 06:46:56 PM »
I'm looking forward to just getting it back Dan, only a few weeks to the attempt and a lot of final checks to go through.
Sam. ;)
Offline HavocTurbo
  • Can you tell?
« Reply #306 on: March 16, 2009, 07:07:58 PM »
Best of luck to you Sam. We are all pulling for you in the colonies.
 ;D
09 XL883L - No Name
« Reply #307 on: March 16, 2009, 08:15:20 PM »
Thanks HT, I just hope it all goes to plan. ::)
Sam. ;)
« Reply #308 on: March 17, 2009, 07:59:25 AM »
i think you'll do great.
you seem like the kinda guy that crosses all the "t's"  and dots all the "i's"
is there a way to post a video for all of us to see you go for it?
Offline Soos
« Reply #309 on: March 17, 2009, 08:21:28 AM »
Sam. ;)
WHA!?
Not sure how I missed that!  Ok, now you REALLY have piqued my interest!!!
I have never heard of a 2 stroke with nitrous!
AWESOME!!
You're running 170'ish cc's right?
Whats the HP/torque #'s for your motor? (before the mods, stock)
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline benly- ben
« Reply #310 on: March 17, 2009, 01:51:28 PM »
as computer whizz for sam green racing ill make sure there is a vid ;D
ben ;)
"Youngest Member On The Forum! Joined When I Was 12!"
« Reply #311 on: March 17, 2009, 02:38:52 PM »
Sam. ;)
WHA!?
AWESOME!!
l8r
Soos, it's 134cc and around 40bhp. Here's the specs for the stock 125 that it started life as.
http://www.fatbaq.com/mainpage.phtml?topic=91_rs125_specs
Sam. ;)
Offline HavocTurbo
  • Can you tell?
« Reply #312 on: March 18, 2009, 11:32:47 AM »
134cc stroker with juice..... I love it!!!
 :D ;D (insert headbanging smiley here)
09 XL883L - No Name
Offline benly- ben
« Reply #313 on: March 18, 2009, 11:44:44 AM »
 :D ;D <a href="http://plugin.smileycentral.com/http%253A%252F%252Fwww.smileycentral.com%252F%253Fpartner%253DZSzeb008%255FZRxdm748YYGB%2526i%253D7%252F7%255F14%255F4%2526feat%253Dprof/page.html" target="_blank">[img width= height= alt=SmileyCentral.com" border="0]http://smileys.smileycentral.com/cat/7/7_14_4.gif[/img]<
ya mean like this
Offline HavocTurbo
  • Can you tell?
« Reply #314 on: March 18, 2009, 11:46:38 AM »
Not quite what I had in mind..... but close enough.
I'd almost pay to see a wheelie on that bike. Especially at 100mph or so.  ;D
09 XL883L - No Name
« Reply #315 on: March 18, 2009, 01:37:47 PM »
It stopped doing wheelies the day I fitted the 6.75" extra long swingarm.
Now it leaves black rubber lines on the road.  ;D ;D ;D ;D ;D ;D
Sam. ;)
Offline HavocTurbo
  • Can you tell?
« Reply #316 on: March 19, 2009, 08:45:29 AM »
You mean it cannot do a wheelie at all???
I might cry Sam.  :P
09 XL883L - No Name
« Reply #317 on: March 19, 2009, 05:37:47 PM »
Without the extensions, it will wheelie untill you hit 5th on quarter gearing.
Geared for 300 yards which is what it was geared for when I first tested it, carried the front wheel untill I closed the throttle in top gear. A hairy scary ride. ;D ;D ;D ;D ;D
Not a good idea when concentrating on getting there quick. ::) ::) ::)
Sam. ;)
Offline sparty
  • I just play one on TV
    • Gallery
« Reply #318 on: March 23, 2009, 05:44:52 AM »
Sam. ;)
Hence the brown spot on the back of those white leathers.   :o
1972 CB750 K2 Cafe' Style
« Reply #319 on: March 23, 2009, 06:56:09 PM »
Got the bike back Saturday with the new ignition fitted.
Took it straight to the dyno only to find it had a flat battery and then the dyno packed up.
When we got home, we charged the battery and on Sunday it fired up with no problems.
The only problem is, I still don't know if the Nitrous system will work under load.
I'll just have to take a chance and run it in April and hope for the best as I can't afford any more testing before the record attempt.
It's fingers grossed time. :'( :'( :'(
Sam. ;)
Offline HavocTurbo
  • Can you tell?
« Reply #320 on: March 24, 2009, 11:49:48 AM »
Best of luck to you Sam. I'll be pulling for you. 3000 miles away.  ;D
09 XL883L - No Name
Offline Soos
« Reply #321 on: March 24, 2009, 06:44:09 PM »
Still can't get over a 2 stroke with nitrous!
Best of luck over there!!!
l8r
-=≡ Soos ≡=-
« Reply #322 on: March 24, 2009, 07:56:31 PM »
Thanks HT, and Soos,I'll see if Ben can post some pics of the nitrous set up and the air shifter that has just been fitted.
To be honest, it looks like a plumbers nightmare :D :D :D :D :D :D
Sam. ;)
Offline benly- ben
« Reply #323 on: March 25, 2009, 03:40:20 AM »
Sam. ;)
Ill get some shots of the plumbers nightmare ;D
Offline benly- ben
« Reply #324 on: March 29, 2009, 02:34:30 PM »
We now have the bike back from the wizards, heres some pics.
The new rev counter, from scitsu, to work with the boyer brandsen ign.
The nitrous purger, the carb and the solenoid, mounted under the front of the seat.
The air shifter, from Orient Express.
The nos bottle and the brains of the air shifter, mounted further back under the seat.
The solenoid on the other side.
The bike.
Mike Rieck is now sams sponsor (I hope I spelt his name right!!!)...
... so is cadishead motorcycles.
The Honda Wing!
Ben ;)
