Author Topic: Slider on Carb Issue  (Read 723 times)
revjim
« on: February 22, 2008, 02:04:35 PM »
I have K carbs that are dated 1977.  They go on a sohc engine honda.  I rebuilt all 4 carbs and when I tried to push the last slider in on the last carb (the carb with the big lever on it) it was really difficult to go down...I had to push, then it went in fine.  It seemed like the first inch or so was difficult then became okay.  Will this cause a problem down the road.  THanks.
Offline Bob Wessner
  • "Carbs Suck!"
Re: Slider on Carb Issue
« Reply #1 on: February 22, 2008, 02:59:13 PM »
I'd investigate why it behaved that way. They should drop in easily. After all, there is not much force used to raise the slides in operation and just some spring pressure to lower them on closing.
Offline Patrick
« Reply #2 on: February 22, 2008, 04:42:00 PM »
If the slider jams at the top when you put it in it also can jam at the top when you are riding the bike.
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
