Author Topic: Probably a STUPID question - Chain Links on CB500  (Read 1571 times)
Offline chopstar500
  • King of the Nighttime World
« on: February 25, 2008, 08:03:17 AM »
I think it is 97 links on a CB500/4 - I did a search & didn't find a definitive answer. Just wanted to make sure before I cut some links out of my new chain.
THNAKS!!!
Completed Project "Four Pack" - My 1971 CB500 KO - Now For Sale - email me for more info!
Offline hymodyne
Re: Probably a STUPID question - Chain Links on CB500
« Reply #1 on: February 25, 2008, 08:30:28 AM »
that sounds a little short to me... you might check earlier links about chains on the site or the service manual
Hym
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #2 on: February 25, 2008, 08:39:00 AM »
You should never cut a chain until it has been fit to the bike that it is being used on.
Measure twice and cut once.
« Reply #3 on: February 25, 2008, 10:51:20 AM »
I know the 550 has 100 links.
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #4 on: February 25, 2008, 11:15:30 AM »
Order a 110-120 link chain and cut to fit.
Roule comme dans les annĂ©es 70...   Roll as in the Seventies...
« Reply #5 on: February 25, 2008, 11:59:22 AM »
Probably best to count the links on your current chain.  The 550 has a larger rear sprocket, so a chain for a 550 might be longer than needed for a 500.
I don't find it listed anywhere.  I assume you don't have the facilities to cut a longer chain to proper length.  Maybe if you call the Honda dealer under the guise of purchase, they may look it up and be able to tell over over the phone the correct length?
Offline hymodyne
« Reply #6 on: February 25, 2008, 12:03:24 PM »
I bought a new 530 chain from JCWhitney, and a master link and didn't have to cut anything.
Offline ct_racer
« Reply #7 on: October 28, 2008, 12:26:39 PM »
hymodyne, how long was the chain you bought from JC?  I need to replace mine on a 500K2 with stock gearing.
Offline Einyodeler
  • Midnight bugs taste best!!!
« Reply #8 on: October 28, 2008, 01:46:36 PM »
My CB500s all run with the stock 17 tooth front and 34 tooth rear sprockets and run a 98 link chain, I usually just buy the 100 link chains and cut down to size.
« Last Edit: October 29, 2008, 07:47:42 PM by Einyodeler »
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
Online Deltarider
« Reply #9 on: October 28, 2008, 02:17:10 PM »
and use a 96 link long chain
Stock is 98 actually.
« Last Edit: October 28, 2008, 02:31:34 PM by Deltarider »
CB500K2-ED Excel black
