Author Topic: Sparkplug question  (Read 1897 times)
Offline Bido
Sparkplug question
« on: February 26, 2008, 03:11:23 PM »
I have a 78 750 SS F3 stock coils and wires should I be using a resistor or non resistor plug I am looking at a set of denso plugs and am not sure of what to use. Whats the story with the premium plugs by denso?
Thanks
Bido
1978 CB750 Supersport F3
1981 CB750 K
Re: Sparkplug question
« Reply #1 on: February 26, 2008, 03:24:08 PM »
If you are also using the stock resistor plug caps, you do not want resistor type plugs.
Offline Jonesy
  • Shop Rat
« Reply #2 on: February 26, 2008, 03:53:47 PM »
How do mean by "premium" plugs? The iridium ones? If so, I think the iridium plugs are only available in the resistor type, so they would not work well with a stock ignition.
The Denso U-groove plugs work well and are better suited for "wasted spark" ignitions, as are on these bikes, IMHO.
Offline Bido
« Reply #3 on: February 27, 2008, 03:22:11 PM »
I ordered a set of X24ES-ZU from Sparkplugs.com would these be the correct plugs?
Thanks in advance
Bido
1981 CB750 K
Offline Jonesy
  • Shop Rat
« Reply #4 on: February 27, 2008, 04:16:51 PM »
If the 750 F used NGK D8EA plugs, X24ES-U is the correct Denso plug.
eldar
« Reply #5 on: February 27, 2008, 06:23:24 PM »
Ok I got a question. The iridium is supposed to be better for low spark systems such as ours. Are you sure the double resistor issue applies to the iridiums? I gather from past threads that it only applies to "standard" plugs.
Offline 333
  • Time for change
« Reply #6 on: February 27, 2008, 06:55:49 PM »
And if you end up using the resistor plugs, will going to a non resistor cap fix the double resistor thing?
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
eldar
« Reply #7 on: February 27, 2008, 07:03:51 PM »
it would with regular plugs but the iridiums are resistor plugs but I was under the impression from past threads on this that a double resistor setup was fine with the iridiums.
« Reply #8 on: February 27, 2008, 11:15:48 PM »
Yes
« Reply #9 on: February 27, 2008, 11:21:27 PM »
Works fine on the CR. 8) 8) 8) 8) 8) 8)
Sam. ;)
eldar
« Reply #10 on: February 28, 2008, 11:09:03 AM »
are you running iridiums with resistor caps?  If so that would be great but then I have stock coils with a dynaS. You think it would work good?
Offline bert96
  • past ride
« Reply #11 on: February 28, 2008, 12:31:48 PM »
 I have iridium and it work fine on my bike!
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
eldar
« Reply #12 on: February 28, 2008, 07:45:46 PM »
you running resistor caps? If so, did you notice or see some improvement?
Offline bert96
  • past ride
« Reply #13 on: February 29, 2008, 03:12:42 AM »
 oh yeah,in fact i like so much iridium spark plugs that i put that in my mustang ;)
eldar
« Reply #14 on: February 29, 2008, 06:08:37 AM »
Which kind did you put in? densos or ngk? and what was the number?
Offline bert96
  • past ride
« Reply #15 on: February 29, 2008, 01:38:08 PM »
 NGK DR8EIX
