Author Topic: Soon to be...  (Read 2528 times)
MPH2
Soon to be...
« on: August 05, 2005, 10:07:38 PM »
I can't wait anymore my last payment is next monday(8-15-05) and i'll have a beautiful cb750k8 in my possion and under my care. The first thing I'll be doing is cleaning the #$%* out of it to make it shine once again. Then once I get the new battery I bought charged it'll be put in. Next I'll be changing the oil and filter. Which beings me to the question what brand and weight should I use. Then i'll change the brake fuild and pads if they are needed.
Then I'll make sure that everything is ajusted right. Then over the winter I'll be buying parts for it that it needs like the oil tank and electrics cover. I'll be buying my gear over the winter too. Then I'll be riding the #$%* out of it.
Buffo
Re: Soon to be...
« Reply #1 on: August 05, 2005, 10:40:02 PM »
I use Mobil 1 MX4T 10w-40. Be aware however you CAN NOT use Mobil 1  oils that are intended for cars!!! You need the stuff for motorcycles.
 This is from the mobil 1 web site......
So how is Mobil 1 for passenger cars different from Mobil 1 for motorcycles?
First, let's be clear about Mobil 1's overall benefits compared to those of conventional motor oils, whether for passenger cars or motorcycles:
Superior long-term engine protection.
Superior high-temperature stability.
Excellent low-temperature starting.
Outstanding engine performance.
Low volatility/low oil consumption
It's a little hard to generalize about the difference between Mobil 1 passenger-car motor oils and Mobil 1 motorcycle oils. That's because not all viscosities of Mobil 1 passenger-car oils have the same levels of zinc and phosphorus, and there are even greater differences among the three Mobil 1 motorcycle oils. In general, Mobil 1 motorcycle oils have:
Additive packages balanced differently for motorcycle engine and transmission operation. For passenger vehicles, fuel economy and emission system protection are higher priorities. These require low phosphorus systems and the use of friction modifiers.
What are the overall advantages of Mobil 1 motorcycle oils?
In addition to the overall benefits listed above – specifically, high-temperature stability and low volatility/low oil consumption – Mobil 1 synthetic motorcycle oils also offer superior anti-corrosion performance compared to conventional motor oil, which is important in many parts of the country where bikes may sit in garages for several months of the year.
Compared to conventional oils, Mobil 1 motorcycle oils provide superior wear and high-temperature protection, and promote engine cleanliness and lower oil consumption.
Once you get past these general advantages, you have to deal with each specific motorcycle oil one at a time to understand the benefits.
Okay. Let's start with Mobil 1 MX4T. What does it offer that Mobil 1 for cars does not?
Mobil 1 MX4T is designed for sport bikes. Most of these bikes have multi-cylinder/multi-valve engines and use a common sump, which means the engine oil lubricates the engine, transmission and wet clutch. So unlike Mobil 1 for cars, Mobil 1 MX4T has no friction modifiers, which could lead to clutch slippage.
The motorcycle oil also has more phosphorus/zinc for enhanced wear protection at high engine speeds and high loads. Remember, most bikes don’t have catalytic converters, so higher levels of phosphorus are not a problem.
In addition, Mobil 1 MX4T uses different dispersant/detergent technology for better high-temperature performance and engine cleanliness. Mobil 1 MX4T is also offered in a different viscosity grade than Mobil 1 for passenger cars.
 Don
Offline 78_SaltLick
  • Honda 1974 550
    • Custom Drum making
Re: Soon to be...
« Reply #2 on: August 05, 2005, 10:47:54 PM »
yeah, join the K8 club, i think a few of us on here got them. I still gotta post a pic of mine, wish i had taken a picture before i dropped it on its side.  :(
Gold sparkle is the place you outta be.
Offline Uncle Ernie
Re: Soon to be...
« Reply #3 on: August 06, 2005, 05:00:33 AM »
Maybe I should feel stupid after that, but I just use Honda oil. If I was riding an endurance or GP, I'd spend more for oil.
You might want to look at the tires, too. If they're too old you'll be riding on round rocks.
Offline jotor
Re: Soon to be...
« Reply #4 on: August 06, 2005, 05:19:34 AM »
Not for long........  :-0
I use the Honda oil in my old bikes and whatever semi-synthetic I can get cheapest in the modern ones.  Not as important what oil to use but how often you change it.
Good luck with the new bike.
I'd rather ride a Yamaha than eat worms.
Gallery.....http://www.sohc4.us/forums/index.php?topic=2254.0
MPH2
Re: Soon to be...
« Reply #5 on: August 06, 2005, 07:23:22 AM »
Yea I going to get good new tires. any suggeses on the brand
Offline Uncle Ernie
Re: Soon to be...
« Reply #6 on: August 06, 2005, 10:06:51 AM »
Battle Axes seem the rage right now- BT45s ( ? ) I think. Seem OK. I do well with Avons, also.
Offline kghost
Re: Soon to be...
« Reply #7 on: August 06, 2005, 12:47:36 PM »
Love the Dunlop Gt-501's. Have them on two 750s.
Stranger in a strange land
Buffo
Re: Soon to be...
« Reply #8 on: August 06, 2005, 03:20:53 PM »
I run Dunlop 491 elite II's front and rear.
Don
