Author Topic: cleaning orig. engine cases  (Read 2159 times)
74 750K
« on: August 05, 2005, 10:54:12 PM »
Hi all,
Newbie here. Bike is a 1974 750K. Question is...I am doing all the required carb maintenance, valves, timing, etc. in search of good health. While I have the carbs off the bike and good access - I am trying to decide whether to address the clearcoat (or whatever it is) on the engine cases.  My question is:
How much of a pain in the ass is it? I have searched and found methods to address the problem, but I'm curious what has worked for you, how nasty the chemicals are, and how much time it took?
Bike is original, a 100% complete bike that has been garaged since day one and is in very nice shape (no rust). 9K miles. I am considering making it roadworthy (will be ridden) without restoring it cosmetically at all. I just don't know if I can stand looking at those engine cases, all yellowed and stuff.... so that is my dilemna. Would I be molesting an otherwise original bike, a crime? Or am I crazy to even consider looking at those ugly cases for one more day...
Inquiring minds want to know.  Thank you for your input.
« Last Edit: August 05, 2005, 10:59:00 PM by 74 750K »
Offline Steve F
Re: cleaning orig. engine cases
« Reply #1 on: August 06, 2005, 03:37:19 AM »
 :o Geez, with a bike in that kinda shape, and low miles I'd get it all pretty again!!!!  I had refinished a couple of engines before, and was really satisfied with the results.  Nothing looks better than a nice clean engine.  There's several methods to preparing the cases for paint, but the worst part is the removal of the engine.  Yes, I'd say you should remove the engine before attempting this.  You just can't do it right with the engine in the frame.  Be careful to protect the frame with padding prior to removal to avoid gouging the frame paint.  You gotta remove the oil filter housing and the exhaust studs (be prepared for a slight battle there, and replacing them).  You would probably need a partner to assist with the lifting to a suitable work surface.  Preparing the engine for paint was simple for me, as I had it MEDIA blasted.  It's a PLASTIC MATERIAL that's like sand blasting, but is NON abrasive, and completely safe for aluminum and any chromed parts.  Just LOTS of degreasing and using heavy or multiple layers of duct tape, masking off the little openings where the media can get into the engine, like the intake / exhaust ports, tach cable hole, breather openings on the valve cover and trans, around where the electrical connector goes into the side by the shift lever and any other little hole that might be a problem. You should also remove the levers from the shifter and kick starter, and put heavy duct tape over the seals, and protect the seal by the output shaft.  I used rubber "corks" from the local hardware store to plug up the exhaust ports, just jammed them in.  I used engine paint from the local autoparts store, or you can get engine paint from the Honda dealer.  The shiney aluminum parts should be clear coated, I used polyurethane clear paint for aluminum wheels, which worked well. That stuff is really thin, and gets runs easily so be careful there.  Mask off all the clear-coat areas, spray the aluminum colored paint first, and then the clearcoat on the bare "polished" parts.
tat2ken
« Reply #2 on: August 06, 2005, 05:21:43 AM »
I took aircraft paint stripper to mine. Removed the clearcoat, then I sanded the covers with different grades of wet or dry ending with 1500. Took the covers to my buffing wheels and made them look like chrome. A bit labor intensive but keeping them bright now is as easy as polishing them with some Mothers Mag polish
74 750K
« Reply #3 on: August 06, 2005, 12:23:37 PM »
Thanks for the responses guys.
Taking the motor out of the frame isn't really realistic for me at this point in time. Two working parents, commutes, toddler and another on the way. And, I have other bikes to maintain.  If I can polish up the motor "acceptably" in the frame, then maybe I will. I WILL do everything right if I HAVE to pull the motor if I were to have lower end problems, etc. But otherwise, I'm not planning on putting the time into this, which is kind of why I asked this question in the first place.
I'd be interested in hearing from any historians out there on whether you think I should keep this bike utterly original, or polish the cases, etc.
Thanks!
