Author Topic: Installing K1+ Carbs on K0 Engine - hell on wheels!  (Read 3445 times)
Offline Magpie
« on: February 27, 2008, 11:13:41 AM »
Hi gang!
The project is coming close but I can't get the carb insulators on a set of K1+ carbs on an early die cast engine, #1021790. Are the intakes  located slightly differently on the K0 motors? I've purchased new insulators and they don't seem to want to go on very well. The 1 and 4 ones look too long. I know it's a tough job but this is rediculous. I did have them on once but the aircleaner top portion wouldn't go on properly. It seems the carbs were sitting too high. The frustration level is getting very high but I'm too close to give up now, besides the $'s spent. I've tried a set of old insulators which seem closer fitting but of course they're rock hard.
I didn't start this project with a complete bike but purchased the engine and frame separately and have been gathering up parts, new and used, to build a "71. I don't think I'll do it this way again.   ;D
Thanks in advance for any help.
Cliff.
Offline kghost
Re: Installing K1+ Carbs on K0 Engine - hell on wheels!
« Reply #1 on: February 27, 2008, 11:18:57 AM »
I don't think thier different....
I heat mine up in hot water to make them more pliable.
Stranger in a strange land
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #2 on: February 27, 2008, 11:25:16 AM »
It's been a few years since I had mine off, but make sure the engine side ones are angled just right (right order of course and the numbers straight up). I seem to recall also there is a slight difference on the airbox side as well. If you look at them carefully, there is a slight difference between the top and bottom of each at the airbox end. That is, there seemed to be a 'top' and 'bottom.' Could be faulty memory on my part though. :-\
Offline Magpie
« Reply #3 on: February 27, 2008, 11:31:24 AM »
Thanks Bob and kghost. Yes Bob, "Carbs do suck"!  ;D
I'll heat these suckers up untill they're putty in my hands.
Cliff.
Offline sandcastcb750
« Reply #4 on: February 27, 2008, 01:29:17 PM »
I put K4 carbs on a K0. It did run slower but I think the jets were to small. I think you need 120 main and 40 slow.
Other than that, ran great. Actually idled.
Offline Head
  • JUST SOME OF THEM- I WAS BUILDING THESE WHEN NEW
    • My Bikes
« Reply #5 on: February 27, 2008, 03:23:58 PM »
I believe that there is a subtle difference between ko --k1 on up to 76
up to 1044805 is different than 1044806 and on up, serial #s    head
1970x2,71,72,74,75K's,75F-FO-750ss, 2 x 75 GL1000, 77 GL1000,  3x 1981 CB900F, 74 550,  1966 CL77 305, 1967 CL77 305, 1974 MX360 Yamerhamer, 1983 CB1100F RED
NOTICE Due to current financial restraints the
Light at the end of the tunnel will be turned off until further notice!! sohc member#1522
« Reply #6 on: February 27, 2008, 08:25:20 PM »
Oil the carb spigots and start on one end, then push...
Offline Magpie
« Reply #7 on: February 27, 2008, 10:13:28 PM »
GOT EM ON! Oil, heat, muscle (my arms and hands hurt) and 2 4x4's worked. Thanks for the encouragement guys! Now I have no spark. I cleaned up the points, set the gap and timed it with a continuity light but now nada. It ran before, not well but it ran. That just goes to show "There's always something...."
Cliff.
