SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Turn Signals....
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Turn Signals.... (Read 1129 times)
Ryan 550k
Guest
Turn Signals....
on:
February 27, 2008, 10:05:17 PM »
Hey everyone. I'm a new member, so if I'm posting this in the wrong place.....sorry, just let me know where to post.
I just recently purchased a sweet 78 CB550k. The only thing that's funky about it is the turn signals are turning on but not flashing. Any ideas about what I can do to remedy that?
Thanks
Ryan
Logged
playinsafe44
Guest
Re: Turn Signals....
Reply #1 on:
February 27, 2008, 10:20:22 PM »
my cb450 twin does the exact same thing. i thought it was something i screwed up in the wiring somewhere. i know i dont help, but id like to know the problem too
Logged
bender01
Master
"Follow the leader.He's on a Honda"
Reply #2 on:
February 27, 2008, 10:21:46 PM »
Try pulling the relay switch. Its near your fuses under the left side cover.Give the connections a good cleaning maybe that will help. I have a 75 550k. Mine still are fidgety and stubborn but after cleaning the connections they work 90% of the time. A new switch is very reasonable from honda like 20-30$. Also mine seem to work better when im riding. At stoplights it sometimes will only beep every couple seconds. At higher rpm under power or downshifting they work great. This is after cleaning the connections. Im still going to buy a new switch soon.
Logged
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
cafe750
Hot Shot
If you can't fix it with a hammer, it's electrical
Reply #3 on:
February 27, 2008, 11:48:12 PM »
You could try a new flasher too, a standard two pin auto flasher will work, if you cant find the stock size. If I remember right, on the 550's it's mounted on the electrical panel, under the left side cover.
Good Luck!
Logged
"It's an old motorcycle, the wind is supposed to blow your head around, it's supposed to leak oil, the brakes should suck, and every now and then, it should scare you so bad you piss your pants."
Roy, Washington
750goes
Master
it will live
Reply #4 on:
February 28, 2008, 12:54:26 AM »
make sure all your "ground" or "earth" connections are nice and clean and tight... that will probably fix most of your problems..... worst case scenario...replace the flasher can...
also a flat or nearly flat battery will show the same symptoms.... a weak battery with bike idling may not flash, increase the rpm and see if they work... if so battery may be suspect....but check all your connections (clean them) first..
Logged
Jakoba
I'm far from a CB750
Hot Shot
Reply #5 on:
February 28, 2008, 05:29:56 AM »
I agree with 750Goes.....90% of the time it's the ground.
Logged
Jako
Member #4500
"See the ditch, see the ditch, in the ditch"
Ryan 550k
Guest
Reply #6 on:
February 28, 2008, 07:55:15 AM »
You guys rule thanks! I'll be checkin all these ideas out in the next week or so.
Logged
Johnie
Really Old Timer ...
Reply #7 on:
February 28, 2008, 09:41:20 AM »
My bet is the flasher. It is a small canister looking thing. Sort of resembles a very small tin can. It slips into a rubber grommet.
Logged
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI USA
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
Turn Signals....
