Author Topic: Stuck Float Bowl Drain Plugs - CB 350F  (Read 2454 times)
Offline CrashBar
« on: March 01, 2008, 06:50:13 AM »
I've checked the Carb FAQ and done a search, but did not see anything on this.  I am half way through rebuilding the carbs on my CB350f.  So-far, so-good, except I cannot get the drain plug screws out of the float bowls.  I let them sit for a week filled with liquid wrench (the graphite solution), but it did not help.  Before I resort to more torque (impact driver or flat blade socket on a 1/2" breaker bar) are there any other tricks?  The screws are very soft.  Will heat help? Should I just drill and tap out the other side and switch them all around left vs. right?
Thanks in advance.
CB
....to trade in these wings on some wheels...
2017.5 BMW R1200GS
1973 CB350F
1978 CB550K
1973 TR5T
Offline greenjeans
  • 1972 CB750K2
Re: Stuck Float Bowl Drain Plugs - CB 350F
« Reply #1 on: March 01, 2008, 08:03:29 AM »
heat gun and some PB Blaster...I had the same problem.   Put some PB Blaster in there and hit it with a heat gun. Give it a shot.   A BIGGER screwdriver will help as well.
Offline CrashBar
« Reply #2 on: March 01, 2008, 08:28:45 AM »
Thanks, I'll give it a try.  I needed an excuse to go to Home Depot today anyway....
2017.5 BMW R1200GS
1973 CB350F
1978 CB550K
1973 TR5T
Offline Bodi
« Reply #3 on: March 01, 2008, 11:22:25 AM »
If you do ruin them, I think Sirius has replacements for a relatively reasonable price...I know I saw some and that's the most likely place. The screw threads are super fine metric, pretty much unobtainable in the western world. Plus the profile is odd with the oversize cheese head, and there are holes drilled through the thing to let fuel drain... so basically making a replacement would be a nightmare.
Offline CrashBar
« Reply #4 on: March 01, 2008, 06:23:56 PM »
Yep, I've already ordered a replacement set from SCI (figured by the time I got them out they'd be pretty mangled no matter what).  Everything is having a good soak in PB blaster at the moment, so let's see what tomorrow (and some heat, and a big screwdriver,  and maybe a pair of vice grips) brings!
2017.5 BMW R1200GS
1973 CB350F
1978 CB550K
1973 TR5T
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #5 on: March 01, 2008, 06:27:49 PM »
give the head of the screw a good wack with a hammer too before wrenching on it. It's sometimes enough to jar the threads.
 Matt.
Gallery at:
Offline Gin Rickey
  • '73 CB350F
« Reply #6 on: March 01, 2008, 06:31:20 PM »
I second.
Offline CrashBar
« Reply #7 on: March 02, 2008, 07:28:19 AM »
Presto - 4 for 4.    Soaked them overnight and gave them a rap with a hammer, and out they came.
Thanks!
CB
2017.5 BMW R1200GS
1973 CB350F
1978 CB550K
1973 TR5T
Offline heffay
« Reply #8 on: March 02, 2008, 09:21:04 AM »
big screwdriver is a good hint... i've always had good luck w/ tricky screws by going over to the box, getting the foot and a half long phillips or flathead and trying again.
i've tried to figure it out but what is it?  just plain more torque?  different hand and arm position resulting in better results?  wtf?
best tool in the box for this purpose though?... impact screwdriver set.  now, if only those little screws weren't buried in that tunnel!  :-\
Offline Gordon
  • 750K1, 550K2
« Reply #9 on: March 02, 2008, 10:49:59 AM »
I don't think I'd use an impact driver on the float bowls.  That weak metal will bend or break too easily.
What tunnel are you talking about?
Offline heffay
« Reply #10 on: March 02, 2008, 03:57:24 PM »
oops... i really didn't mean to put "for this purpose".
i think i may have meant something like, stuck screws that you don't want to strip the head on...
thanks gordon.   :P
Offline heffay
« Reply #11 on: March 02, 2008, 04:02:45 PM »
carb screws, whichever ones they are... inevitably seem to be in some sort of ridiculously slender tunnel.  whether these particular ones are or not was not really my point.  joking about the pain in the assness of carb work and stuck screws.
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #12 on: March 02, 2008, 05:30:08 PM »
It sounded like you were talking about a snowmobile tunnel (Chassis). whenever a screw is droped under the hood of a sled, It will no doubt come to rest under the engine in a pool of goop on the bottom of the tunnel, only retrievable with a telescoping magnet and and a large flashlight  :D
 Matt.
Gallery at:
Offline heffay
« Reply #13 on: March 02, 2008, 06:01:20 PM »
i hate THAT tunnel... i've dropped many a battery bolt down those  >:(
