Author Topic: CB650 Splitting Cases ..... Rotor Removal????  (Read 2115 times)
Offline CBJoe
« on: March 01, 2008, 06:15:27 PM »
I'm having problem splitting the cases on my '80 CB650C and before I break something, I figured i'd ask.
Do you have to remove the rotor to split the cases on a CB650??  None of my manuals mention it but I read a comment from
http://www.myhonda650.com/cb650project.htm  that says that it's a must.
thanks... Joe
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
Offline CBJoe
Re: CB650 Splitting Cases ..... Rotor Removal????
« Reply #1 on: March 01, 2008, 09:06:59 PM »
Thanks for the confirmation.
Murphy's law has struck again, in that now I cant get the $#@* rotor off  :(
The rear axle threads in fine, but with the motor out and on the work bench I cant seem to get enough leverage to break the rotor free from the shaft.
I got angry at the motor, so I decided to drink some beer and tackle it tomorrow.
later... Joe
'65 CB77
'66 CM91 (C90'ish)
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #2 on: March 01, 2008, 10:37:51 PM »
sorry, but i gotta disagree. you don't have to remove the rotor to split the cases, though it's much easier to do so before pulling the engine unless you have compressed air and an impact wrench. the crank seals at both ends of the case on the 550/650, and the seals can bind to the case surprisingly well. if you're sure you have every bolt removed, tap around lightly with a rubber mallet or deadblow. if it still won't come, knock upwards on the rotor a little bit with the mallet.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
InaneCathode
« Reply #3 on: March 02, 2008, 12:07:30 AM »
I've removed a few rotors in my day, it seems the key to getting them off is to get good even pressure with a puller all the way around and straight. Then give the puller a good few smacks. You also can smack around the rotor and on the puller arms.
Offline cb650
« Reply #4 on: March 02, 2008, 12:39:57 AM »
You dont need to split the cases.  I had one be verry stubborn striped the threads in the rotor not the axle. used a puller and still had to use a little heat.
                      Terry
« Last Edit: March 02, 2008, 12:42:13 AM by cb650 »
Offline CBJoe
« Reply #5 on: March 02, 2008, 07:22:26 AM »
Thanks for the info.  I think things are being complicated by the fact that the PO brush painted the motor with a really thick coat of paint.  I'm going to work at it with a wire brush to ensure that the upper/lower cases aren't being sealed together with paint.
If I don't have an impact wrench and the engine is on the bench, what is the best method to holding the crank in place so that i can put some force into threading the rotor puller/rear axle?
thanks... joe
'65 CB77
'66 CM91 (C90'ish)
Offline CBJoe
« Reply #6 on: March 02, 2008, 09:20:24 AM »
Paul.... Are you sure that the rotor doesn't need removed??  After scrapping and brushing the seams, I got the cases to split, but I cant get them to fully separate where the rotor is  :(
I would remove the rotor, but with the motor on the bench and stripped down as much as it is, I cant figure out how to keep the crank from spinning.  Strap wrench??
thanks... Joe
'65 CB77
'66 CM91 (C90'ish)
« Reply #7 on: March 02, 2008, 10:30:22 AM »
The stock tool for the 750 is put on by hand then struck to loosen.
If you use a tool that looks like a bolt simply hold the rotor and give the wrench a whack with a soft hammer or 2x4, then strike to tool to remove.
An axle may fit, but it is not made to do that job, but people keep on using them...
Offline paulages
  • 1976 cb735
« Reply #8 on: March 02, 2008, 11:01:15 AM »
I have one sitting on my garage floor that seems to be stuck on the rotor. it has come apart everywhere else. I'm sue it's the rotor binding mine up.
i could really be remembering wrong, as i've only split the cases on a run 650 engine once, but when mocking up the 718 i assembled and disassembled plenty of times with the rotor always attached to the crank. done several 550s though, and they all were the same: it feels like there's something binding at the crank, but it's just the seal sticking. do you have the engine upside-down?
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline CBJoe
« Reply #9 on: March 02, 2008, 03:05:35 PM »
Yep... I've got it upsidown.  I'm convinced at this point that its the rotor holding it on.  It seems that the cases are slightly inset into the backside of the rotor. I'm going to bolt them back together and take the engine to a friend that has an air impact wrench.
Thanks for all the help... I didn't intend to start another "how do i remove the rotor" thread  ;D
I just cant believe that got myself to stop prying at the cases .... I usually go to far and break things  ::)
cheers.... Joe
'65 CB77
'66 CM91 (C90'ish)
Offline purf_man
« Reply #10 on: March 02, 2008, 04:00:13 PM »
on my 550 I used a strap wrench (nylon type) and on a wild whim the bolt from a harbor freight power steering puller (same thread as a axle bolt or a purpose built puller and just as checp but comes with other goodies)  I greased up the tip of the bolt to overcome friction better and crank and it just "popped" loose.  it is a taper fit so should just let go all at once and fall out.
even with the cases protruding into the backside of the rotor I would think you could at least get them loose.
1975 CB550
1978 RD400
Offline CBJoe
« Reply #11 on: March 02, 2008, 05:30:13 PM »
Thanks purf_man... i'll check that out at harbor freight next time i'm there.
Then end goal is to split the cases for a rebuild, i just hadn't intended to pull the rotor so i was caught unawares.  I think the tool gods are telling me to buy a strap wrench so I must heed their word  ;)
Cheers... Joe
'65 CB77
'66 CM91 (C90'ish)
Offline CBJoe
« Reply #12 on: March 08, 2008, 03:04:06 PM »
Wohoo  ;D   +1 on the strap wrench.
I got a cheep strap wrench from the auto store and used it in combination with the rear axle. It worked great.  I even popped the rotors off my other two parts engines.  Took less that 2 minutes for all three.
Once the rotor was removed, the cases pulled right apart.  Either the rotor was causing the problem or while screwing with the rotor I fixed whatever the snag was. So now its time to start making a list of things to buy from honda.
Cheers.... Joe
« Last Edit: March 08, 2008, 03:06:54 PM by gundum »
'65 CB77
'66 CM91 (C90'ish)
