Author Topic: 76k miss in cylinder 1  (Read 1238 times)
amalcarb
« on: March 01, 2008, 06:59:39 PM »
I have a 76k with only 6600 miles on it. It recently started an occasional miss on cylinder 1. I've cleaned the points, replaced plugs,cleaned the entire fuel system including the tank and cleaned the carbs. I also replaced the #1 rubber boot between the carb and manifold. Still have the occasional miss on the one cylinder about every 20 to 30 revs. Backfires through the pipe not the carb. Help!
Offline 750goes
  • it will live
Re: 76k miss in cylinder 1
« Reply #1 on: March 01, 2008, 08:06:13 PM »
sticky valve ?? or valve adjustment needed ?? colour of plug ??? could be running a trifle rich..
amalcarb
« Reply #2 on: March 08, 2008, 04:05:22 PM »
Thanks for your response. The plug shows it's a little lean. Exhaust or intake valve?
222CT
« Reply #3 on: March 08, 2008, 04:12:36 PM »
i say check em both....and then since you are there check em all.
Offline 736cc
« Reply #4 on: March 08, 2008, 05:05:22 PM »
   Coil wires a usual suspect...run the bike in the dark and look for sparks bouncing around plug.
Offline joeb
« Reply #5 on: March 09, 2008, 03:42:20 PM »
I had a miss in my engine it was a valve adjustment.
« Reply #6 on: March 09, 2008, 04:04:06 PM »
How old are your plug caps mate? I had a miss in #4 on my K0 (old NGK caps) so yesterday I found an old OEM cap and replaced it, and it is much better, but tomorrow I'll go buy four new ones and I reckon it'll be gone completely! Cheers, Terry. ;D
