Poll
gas leaking
Gas
0 (0%)
Leak
0 (0%)
Total Members Voted: 0
Author Topic: 1980 CB750f  (Read 1103 times)
Wannabe
1980 CB750f
« on: March 03, 2008, 07:02:29 AM »
I just started this thing up after sending out the carbs to rebuild. As soon as gas got through, it started leaking gas through the overflow tubes until I shut the gas off. Any ideas as to whats happening? Thanks for your help...
Offline Cvillechopper
  • Is just pretending to be an
  • If not for my failures I'd never know my limits
Re: 1980 CB750f
« Reply #1 on: March 03, 2008, 08:03:05 AM »
My guess is they didn't set the float height correctly or they installed them upside down.
It is the mark of an educated mind to be able to entertain a thought without accepting it.  Aristotle
Offline S-Dog
Re: 1980 CB750f
« Reply #2 on: March 03, 2008, 10:53:06 AM »
+1
I had a similar problem myself.
1975 CB750K Bright Orange with 8300miles
1983 GL650 Silverwing Restore project with 17k miles
http://www.NEHondaGuys.info/forums
Offline kirkn
Re: 1980 CB750f
« Reply #3 on: March 03, 2008, 12:13:51 PM »
Once or twice over the years, when I've had a carb apart for cleaning, the float stuck open when first used.  No idea why.  On those occasions, I've just tapped the float bowls lightly with the handle of a hammer, and the problem disappeared, never to occur again.   ???
Probably my own clumsy reassembly, but I'd give it a try, anyway.
Seems unlikely that the shop would've done this work, and not tried it out themselves.  Something catastrophic like an upside part or misadjusted level would have shown up for them just as quickly as it did for you.
Good luck with it,
Kirk
*edit*  oops, just re-read your post - not sure if you sent the whole bike, or just the carbs themselves.  Hmmm...  I'd still give the tapping thing a try.
K.
« Last Edit: March 03, 2008, 12:16:45 PM by kirkn »
