Author Topic: K0 Ignition Switch  (Read 1149 times)
Offline Magpie
K0 Ignition Switch
« on: March 03, 2008, 08:41:51 AM »
I have a 12/69 built K0 that has the ignition switch hard wired into the wiring harness. Yet I see "sandcast" ignition switches on Ebay with brown connectors on them same as the other 750 I have. When did this change? Or do have the incorrect harness on this bike?
Thanks,
Cliff.
Offline mystic_1
  • 1970 CB750K
Re: K0 Ignition Switch
« Reply #1 on: March 03, 2008, 08:46:32 AM »
Not sure, but I can tell you that my diecast, built 02/70, has the round brown connector on the ignition switch.
Have you checked for evidence of splices?
mystic_1
- John Augustus Shedd
Offline JLeather
« Reply #2 on: March 03, 2008, 08:50:01 AM »
Is your switch still a "recessed" type, that is the key has a black plastic disc that sinks into the switch when you turn it.  if not, then what probably happened is someone got a later switch with a square connector and spliced it into the harness, which should have a round connector.  Square peg in a round hole...
Offline markb
  • When I finish my current project I might be a
« Reply #3 on: March 03, 2008, 08:53:23 AM »
I have a 12/69 build K0.  My ignition switch has the standard brown connector.  It also has the recessed keyhole which I think is what everyone refers to as sandcast.  If yours doesn't have that I would guess someone has spliced a replacement into the harness.
Mark
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
« Reply #4 on: March 03, 2008, 09:12:57 AM »
No Honda SOHC has a hard wired switch it must be a "mod"
Offline goon 1492
  • Sucka Repellant
« Reply #5 on: March 03, 2008, 09:21:02 AM »
Is it evident that it has been spliced, sounds like a splice.
Offline Magpie
« Reply #6 on: March 03, 2008, 09:21:33 AM »
Thanks guys! Lots of strange things about this bike but it does have the correct carbs, side panels, airbox and ducktail seat (in poor condition).
Cliff.
