Author Topic: Stainless brake lines....check these out.  (Read 2582 times)
Offline greenjeans
  • 1972 CB750K2
« on: March 04, 2008, 06:36:53 AM »
Z1 has added stainless brake lines & fittings etc.  Seems like a good deal
Check 'em out:  http://www.z1enterprises.com/catalog.aspx?pid=MFGO0
Question 1:  Any body know what size the banjo bolts need to be at
               1. the master cylinder  -  10mm x 1.25  or  10mm  x 1.00
               2. the caliper - 10mm x 1.25 or 10mm x 1.00
               3. the brake light switch - 10mm x 1.25 or 10mm x 1.0
               4. at the hard line into the caliper.
Question 2. Is it necessary to use the rigid/hard line leading into the caliper, or can
                you just get the stainless hose a bit longer and eliminate that connection?
                It it more of a safety issue (not getting tangled in the wheel spokes?
Offline Roach Carver
Re: Stainless brake lines....check these out.
« Reply #1 on: March 04, 2008, 06:40:54 AM »
it is certainly possible to go from the master to the claiper. You will loose the brake light sending unit unles you are using a more modern mc with the sender built in.
Offline cbass*gxc
    • My Pics Page
« Reply #2 on: March 04, 2008, 07:23:12 AM »
Actually one of the places I looked has banjo bolts with the brake light switch built in.  So you replace the banjo bolt at the MC with this and it has 2 wires coming out.  Actually here is the site.  The bolts on the bottom right with the wire coming off are the switches.
http://www.spieglerusa.com/cfm/brakeacc.cfm
Offline doobiebro
« Reply #3 on: March 04, 2008, 07:26:44 AM »
All of the SOHC 750s use a 10mm x 1.25 banjo bolt.  As 71cb750 stated, you may go from the master directly to the caliper, but need the brake switch.  A newer m/c will have the switch built in, or if you keep your current m/c, you can get a banjo bolt with the switch built in.
Offline dusterdude
« Reply #4 on: March 05, 2008, 12:39:11 PM »
or use the stock switch mount.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
« Reply #5 on: March 05, 2008, 01:05:30 PM »
the point of the ss line is to reduce the sponginess of the lever. If you get stanless to the hard line, you cant do much better than that. Is there a fitting to go from the stainless to the metal line?
Offline mystic_1
  • 1970 CB750K
« Reply #6 on: March 05, 2008, 01:24:01 PM »
I'd like to know what the specs are for that connection, too.  I've seen ss brakeline kits on ebay that connected to the hardline, but didnt like the style of the hoses themselves.  I'd like to run straight from the master cylinder (with a banjo-bold brake switch) to the hardline.
Figuring out what that specific connection is called, and what size it is, is one of the little things I have on my "list of things to follow up on" that I have not yet gotten to lol.
mystic_1
- John Augustus Shedd
Offline Helo229
« Reply #7 on: April 22, 2008, 06:27:21 AM »
I've been looking at the same items on Z1 myself. I just ordered a new M/C with the sensor built in, so I was hoping to run a SS line directly into the caliper. Any thoughts on how to make the connection without the steel brake line? I looked at it for a while and it doesn't seem as though you could put a banjo bolt onto it, it's too small a diameter hole. Any thoughts on what kind of hardware you would need?
Offline cbass*gxc
    • My Pics Page
« Reply #8 on: April 22, 2008, 06:36:17 AM »
Helo check out this topic.  It has all the info about running straight from the m/c to the caliper.
http://forums.sohc4.net/index.php?topic=19177.msg202556#msg202556
Offline Chicago550
  • 75 CB550
    • Gallery
« Reply #9 on: April 22, 2008, 07:22:06 AM »
Talk to Craig at HELUSA. I just got a set of SS hoses from them that work great. I told him that I wanted to get rid of the hard line but keep the switch and he knew exactly what I was talking about. You can even choose from different colors. Look around, lots of people use them. ;)
75 CB550
70 CB350 gone to new home
Offline hymodyne
« Reply #10 on: April 22, 2008, 11:46:42 AM »
I sent Craig an email and got beck an automated response stating that he's swamped with orders right now, but that he will respond to each message and request he gets.
Hope he gets to it before i buy my ss lines from somewhere else...
hym
Offline Helo229
« Reply #11 on: April 24, 2008, 04:42:01 AM »
Hey, thanks Cbass - after looking on the post you mentioned I realized that it was a 10mm x 1.25 fitting on the caliper. When I was inspecting it on my bike, it seemed to be smaller, but once I re-examined it, voila.
Z1 sells the fitting (Brake Hose 10MM X 1.25 MALE TO MALE ADAPT TU03-6239>> http://www.z1enterprises.com/detail.aspx?ID=3349) that the guys on the other post were describing.
It looks like it should provide a nice clean install, eliminating the need for either a banjo bolt or the metal brake like. I'll be placing an order soon as I get my paycheck this week, I'll be sure to let you all know how it turns out, since there seems to be a good deal of interest in the Z1 'build your own SS brake line for cheaper than dirt'. I just guessed all my hose length needs (will actually measure before I order) and my total before shipping was only $72 for all the hardware needed to replace the front and rear lines on my 750F1 (single front/rear rotor).
« Reply #12 on: April 24, 2008, 06:55:11 AM »
Yup, run a 10 x 1.25  to AN 3 or AN 4 fitting on both master and caliper. Then measure bike on center stand without weight on front wheel, pay attention to routing and attach  points, give it a slight slack.(for single disc)
Then simply make up the line yourself, or order the length you need.
Somtimes I would drill the stem nut and run thru the stem, works great on dual disc.
Offline bunghole
« Reply #13 on: August 21, 2008, 01:07:35 PM »
Sorry to revive this thread, but am I understanding correctly that you can eliminate the banjo bolts on both the MC and caliper using the Goodridge lines available from Z1?
And this part --> http://www.z1enterprises.com/detail.aspx?ID=3349
screws directly into the caliper?
Thanks!
'05 HD FLSTCI (Heritage)
'06 Suzuki DRZ400S
'08 Honda VFR800
'77 Honda CB750K
BigDaddyP77
« Reply #14 on: August 21, 2008, 03:38:46 PM »
Sweet!!! looks like i'll be able to replace my lines with SS on my 81 650c (dual disc f/drum rear)  I've been looking for this info!!
