Author Topic: Nuetral Light Wire  (Read 1576 times)
66shorty
Nuetral Light Wire
« on: March 04, 2008, 04:01:33 PM »
Well, I'm rewiring right now and I've com to a bit of a hurdle.  In the handful of wires that are coming out of the engine, the one I'm confused about is the neutral light wire; it's the LG/R (light green/red).  How do I terminate that wire?  Do I just leave it alone in the plug, do I loop it to itself, loop it to ground, loop it to another wire?  I dunno... but I figure it never hurts to ask.
-Kurt-
Offline Gregorymoto
  • SOHC Aficionado
Re: Nuetral Light Wire
« Reply #1 on: March 04, 2008, 04:23:05 PM »
I just took mine off, are you wanting to use it?
Yep, i have issues with this sort of stuff.
Offline Jonesy
  • Shop Rat
« Reply #2 on: March 04, 2008, 05:15:07 PM »
The neutral light is constantly fed power and activated by completing the ground side of the circuit.
So, if you want the neutral light to function, connect it to the neutral switch on the engine. If you don't want the neutral light, leave the wire unconnected and the exposed end covered. If the wire touches the frame anywhere, it will complete the ground and the light will come on.
Hope this helps.
Offline mystic_1
  • 1970 CB750K
« Reply #3 on: March 05, 2008, 09:56:35 AM »
If you're really ambitious, or anal-retentive like me, you should be able to fish the neutral lead out of the engine and disconnect it at the bullet connector where it joins the main harness.  That way, fewer dangling thingies.
mystic_1
- John Augustus Shedd
Offline Gregorymoto
  • SOHC Aficionado
« Reply #4 on: March 06, 2008, 06:57:42 AM »
Hay are you doing this on the chopper?
Is is is a stock wiring harness?
Offline Gregorymoto
  • SOHC Aficionado
« Reply #5 on: March 16, 2008, 08:29:56 AM »
hear is my suggestion, keep the stock wiring harness and build a new one, it is easy and will only take 4 hrs if you don't know what you are doing and 2 hrs if you do.
If you need a copy of a strip down wiring diagram let me know.
Offline mystic_1
  • 1970 CB750K
« Reply #6 on: March 17, 2008, 04:54:03 PM »
One other question, why should I keep the stock one?
1. As a reference while building the new one.
2. As a backup in case the new one fails.
mystic_1
