Author Topic: 78 550k carb tube question  (Read 1569 times)
Offline cijiwij
« on: August 07, 2005, 04:21:25 PM »
Actually two questions.
1. i have a tube next to the gas line that goes to nowhere and I am wondering if I can or should route it any where??
2. I took the carbs off and soaked them in  gas then cleaned them but now one is leaking gas at the float bowl seam..does this mean the seal is bad??
Thank you.
Re: 78 550k carb tube question
« Reply #1 on: August 07, 2005, 05:58:03 PM »
1.  Probably you're taking about a vent fitting.  Attach a hose and route it between the swing arm and the motor.
2.  Yes. the seal becomes brittle with age.  Replacement is indicated/
Offline cijiwij
« Reply #2 on: August 07, 2005, 06:21:02 PM »
Thank you. I have a clymer but I can not find the same carbs with the two lines on top between 1/2 carbs..it won'e reach to the swingarm it apears to be hanging ner the underside of the tank. There is no crud so it does not apear to carry anything out...
I figured as much about the seal.
« Reply #3 on: August 08, 2005, 06:13:52 AM »
The only manual that covers those carbs is the genuine Honda supplement
Offline cijiwij
« Reply #4 on: August 08, 2005, 01:57:22 PM »
I am still wondering where to run the extra hose.....
Offline 5youngs
« Reply #5 on: August 08, 2005, 02:06:47 PM »
If it is the tube next to the gas inlet (from the gas tank to the #2 carb) I ran it it up along the frame tube that the tank mounts on.
It sounds like the carb vent tube.
Offline cijiwij
« Reply #6 on: August 08, 2005, 02:11:57 PM »
carb vent tube..yes it is right next to the fuel tube going in to the carb..so it does not leak fuel or anything?
It seems to me that it ran near the tank vent tube for a bit and just ends near the rear of the tank...
Offline 5youngs
« Reply #7 on: August 08, 2005, 02:14:54 PM »
I routed ours up along the upper frame tube that the tank mounts to.
Perhaps I did it wrong.
Offline cijiwij
« Reply #8 on: August 08, 2005, 02:31:14 PM »
It seems to be the only place it could go..thank you..
