Author Topic: tappets .002 or .02 difference in my manual  (Read 1538 times)
Offline greenjeans
  • 1972 CB750K2
« on: March 08, 2008, 10:48:04 AM »
1972 CB750k
Ok, I have conflicted info coming from HONDA manuals.
When setting tappet clearance - one book has the Intake as:  .002 inches  and the Exhaust as .003 inches
The other book has the Intake as.02 inches and the Exhaust as .03 inches.   What a difference a decimal place makes...
Anyone care to split the tie ?
where did you get your tappet feelers ?  The smallest I have on mine is .008 in     Are these a specialty motorcycle item?
Or should I be able to find these at Sears / AutoParts stores etc.
Offline Soos
Re: tappets .002 or .02 difference in my manual
« Reply #1 on: March 08, 2008, 10:53:32 AM »
I REALLY hope that that is a typo!!!!!!
.002 sounds more like it.
You CAN run with more clearances.... but i wouldn't recommend it.
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
fuzzybutt
« Reply #2 on: March 08, 2008, 10:55:49 AM »
i got my .002 and .003 feelers at advance auto i think.
Offline mystic_1
  • 1970 CB750K
« Reply #3 on: March 08, 2008, 11:00:04 AM »
Definately .002 and .003.  All of my books say this.
Re: the feeler, look for an ignition feeler set.  Don't remember where I bought mine but it's Excel/Kastar brand.  Has very thin gauges, including some that are brass I believe.  Steel ones go from .030 down to .0015 and brass ones are .016 to .006
mystic_1
- John Augustus Shedd
Offline greenjeans
  • 1972 CB750K2
« Reply #4 on: March 08, 2008, 11:38:09 AM »
thanks, .002 & .003 it is.   Got some feelers at pep boys...  (3rd stop)
Thanks again
« Reply #5 on: March 08, 2008, 11:46:12 AM »
Geez..mine are set at .012  :o
 but it is not stock..
.002 &.003 sounds correct to me
Offline dustyc
  • I don't know why anyone would call me an
  • 1977 CB750K
« Reply #6 on: March 08, 2008, 12:18:05 PM »
Make sure you're using the right values on the feelers also.  They may be marked only in standard or metric.
.08 standard = .003 metric
.05 standard = .002 metric
Wait.  Strike that. Reverse it.  Thanks mystic for catching that.  That'd confuse him for sure.
« Last Edit: March 08, 2008, 12:27:48 PM by dustyc »
1977 CB750
Offline mystic_1
  • 1970 CB750K
« Reply #7 on: March 08, 2008, 12:22:36 PM »
.002 and .003 are inch measurements.
the metric values in the book are .05mm and .08mm
my gauges are .002in/.051mm and .003in/.076mm
.002mm would be VERY thin indeed lol :)
mystic_1
Offline crazypj
  • I'm brill, me
« Reply #8 on: March 08, 2008, 12:46:25 PM »
1972 CB750k
0.02" is twenty thou, way too big.(unless you wan the valve tips beaten in?) The correct clearance is two thousandths of inch intake and three thousandths of inch exhaust ( same on ALL screw and locknut Honda's from about 1970~1978 including the later models-XR/XL100/110/125/185/200 etc)
PJ
« Reply #9 on: March 08, 2008, 02:38:59 PM »
That is ..Hondas with Stock camshafts.
If you at all suspect.. or just for kicks.. cuz you only get one chance at this.. check them before you adjust and write them down.. that way if you do have a lumpystick you at least have a general idea what they should be. Once you adjust them you are hooped.. I know of sohc,s where no one knows what the clearances should be, they are just plain guessing!!
To hear mine run you would not believe they are at .012 but it has a long duration..
« Last Edit: March 08, 2008, 02:43:53 PM by 754 »
