Author Topic: CARB ADJUSTING  (Read 1009 times)
revjim
CARB ADJUSTING
« on: March 08, 2008, 12:50:14 PM »
I have a SOHC 74 engine.  My carbs are 77K carbs.  The position is as low as it will go...is this too high?  http://i252.photobucket.com/albums/hh19/revjimmc/DSC00877.jpg
Re: CARB ADJUSTING
« Reply #1 on: March 08, 2008, 12:52:44 PM »
Yes. if you are looking for an idle.
You should be able to close the slide completely with the idle adjustment backed out.
You really should tells us what engine you have.
revjim
Re: CARB ADJUSTING
« Reply #2 on: March 08, 2008, 01:02:52 PM »
I have a CB750 SOHC 74.
revjim
Re: CARB ADJUSTING
« Reply #3 on: March 08, 2008, 01:03:31 PM »
If I push them down from the top...that is as far as they want to go down...I am really confused.
Re: CARB ADJUSTING
« Reply #4 on: March 08, 2008, 01:04:46 PM »
Have you messed with the individual slide adjustments?
revjim
Re: CARB ADJUSTING
« Reply #5 on: March 08, 2008, 01:07:56 PM »
rebuilt all four carbs...took them apart completely...not that hard.  Although something just isn't right...
revjim
Re: CARB ADJUSTING
« Reply #6 on: March 08, 2008, 01:13:15 PM »
GOT IT!!!!!  Thanks guys...had to adjust the top spacer nut...
