Author Topic: Tacho  (Read 1225 times)
Offline dpen
Tacho
« on: March 08, 2008, 04:24:32 PM »
This should go in the "parts" but I'd like to try it here for a day or so then I'll wipe it.
I'm after an aftermarket tacho for my K7/K8 (june'78 build) rat
I'm not interested in originality but can't find anything in Oz to run off the twin coil system
« Last Edit: March 08, 2008, 04:39:15 PM by dpen »
Offline 750goes
  • it will live
Re: Tacho
« Reply #1 on: March 08, 2008, 05:58:02 PM »
So you want an electronic tacho, not the cable driven one.
I suppose you could get one if possible for a 4 cylinder car ??, would that work ??
Offline joeb
Re: Tacho
« Reply #2 on: March 08, 2008, 06:34:31 PM »
Get ahold of scondon I think his tach is eletronic.
Offline dpen
Re: Tacho
« Reply #3 on: March 08, 2008, 10:31:17 PM »
Electronic is what I'm after but car ones are no good as they're made for a single coil system.
I've contacted quite a few instruments places & they've all said "no chance"
troppo
Re: Tacho
« Reply #4 on: March 08, 2008, 10:33:43 PM »
i wouldnt know what would be involved, but what about modifying a later model tach from a bike, one of the naked style bikes would probably provide one that looks right
Offline dpen
Re: Tacho
« Reply #5 on: March 08, 2008, 10:37:04 PM »
I thought of that but wanted to see if one was buyable first so I don't have a lot of mucking around to do.
I rebuilt my present one but the rotor on later Ks is different & the tacho becomes inaccurate as the revs increase
Offline tinyrobot
  • Mock it up before you Fock it up!
    • ChiVinMoto
Re: Tacho
« Reply #6 on: March 08, 2008, 10:41:38 PM »
I'm in the same boat.  I'll let you what I find.
http://forums.sohc4.net/index.php?topic=31595.0
Offline dpen
Re: Tacho
« Reply #7 on: March 08, 2008, 11:02:35 PM »
just read your post Robot - looks like there's a market for one of these things
kta
Re: Tacho
« Reply #8 on: March 09, 2008, 03:26:30 AM »
Couldn't you just splice the wires for the spark sensor into more than 1 coil? I don't see how this would cause any significant issues.
troppo
Re: Tacho
« Reply #9 on: March 09, 2008, 03:51:20 AM »
but if you did that you would have to cut the tach open and remark the face for a reading that is out by 75%
Offline dpen
Re: Tacho
« Reply #10 on: March 14, 2008, 02:37:55 AM »
Aren't there some great people around.
Found a web page here in Oz advertising tachos.
I wrote the bloke asking his advice on the models advertised, where to get them etc.
I received an answer "we are wholesale, we don't sell direct", that was it
Bloody turkey, even if I knew where they are sold he can get stuffed.
Online bryanj
Re: Tacho
« Reply #11 on: March 14, 2008, 03:25:28 AM »
Can you not just run off one coil and re-calibrate?
Offline 750essess
  • Orleans Cycle Repair & Resto
Re: Tacho
« Reply #12 on: March 14, 2008, 05:15:03 AM »
Motogadget makes a tach/ speedo that works
http://www.motogadget.com/en/webshop_en/index_webshop.htm
Or you could run a dyna2000, it has a tach output wire that works with the auto tachs
there are some other brands, but I dont remember what they are.
Orleans Cycle Repair and Restoration
76CB750F
69Z50
XR650L
