Author Topic: plug wires  (Read 935 times)
Offline joeb
plug wires
« on: March 08, 2008, 05:43:01 PM »
When I hold the throttle at anything over 4 grand I get a miss in the engine when I crack the throttle it runs like a raped ape I have the 78 carbs  on my 836 .  The carbs are shimmed so I know its getting enough fuel and I checked the fuel level in the bowls, thanks Sean for the info.  My last thing will be a complete tune up ,valves etc check timing the works. Could it be one of my plug wires. right now I am using 8.8 mm graphite core excel wires , and would like too change to copper core maybe a dyna 7 mm  size will this work. Also any other ideas what the miss may be. thanks
Offline mystic_1
  • 1970 CB750K
Re: plug wires
« Reply #1 on: March 08, 2008, 06:18:20 PM »
check your advancer springs?
mystic_1
- John Augustus Shedd
Offline joeb
Re: plug wires
« Reply #2 on: March 08, 2008, 06:29:17 PM »
I'll check them when I check the timing on my dyna-s ignition. You never know the plate may have moved little.
Offline joeb
Re: plug wires
« Reply #3 on: March 09, 2008, 03:39:39 PM »
Well here is where I stand checked the valves found #4 intake real tight ,feller gauge would not go in .  Checked timing spot on, added another shim to the carbs syncronized carbs put things back together and test drove ran like a cat with fire crackers attached to its tail . All is well in mudville again. ;D
