Author Topic: cant pull clutch lever?  (Read 4289 times)
Offline zeus87
Re: cant pull clutch lever?
« Reply #25 on: April 19, 2008, 09:31:40 AM »
alright i'll keep trying.. It grabs at the slightest release of the lever, you really need to hold the lever flat againts the handlebar to stop any clutch drag.  So i adjusted it out a little (screwed in the bolt on the clutch cover).  Is it possible that my cable could be shot?( stretching?) thanks-Justin
Offline Tower
  • Only at conception could I have been called a
  • My personal time machine: 1973 CB750K3
« Reply #26 on: April 19, 2008, 09:56:07 PM »
As long as you are able to adjust using the handlebar nut and lower lever nut, the cable is probably OK.  Its not very likely that it could stretch enough during tensioning to cause a problem.  Its much more likely that the new plate thickness is adding up to such a close tolerance that you are having difficulty finding the exact spot needed.  Some clutch disk/plate combos are not ideal.  Best to use Honda plates/disks and aftermarket (or Honda) springs, or try removing the last friction disk (next to the pressure plate) and readjust from scratch.
