Author Topic: 400F bore tolerances  (Read 956 times)
Offline fmctm1sw
« on: March 10, 2008, 07:09:09 PM »
I took my 400F cylinder to the local machine shop.  What exactly is the cylinder ID assembly standard?  and service limit?  Does it also have an "out of round" limit?
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
Re: 400F bore tolerances
« Reply #1 on: March 10, 2008, 08:08:33 PM »
Cylinder ID Standard: 51.00mm to 51.01mm
Cylinder ID service limit: 51.1mm
...From Honda Manual: 350-400 Fours
Not sure about out of round.... but it should be fairly round  ;D
 Matt.
Gallery at:
Offline crazypj
  • I'm brill, me
« Reply #2 on: March 11, 2008, 12:11:31 AM »
They should just measure it and give you the results. (then you can post them here to find out if its any good  ;D)
You 'should' have 6 measurements per cylinder, (top, middle, bottom, X-axis, Y-axis)
X-axis usually in line with the pin, Y is thrust face and generally where the wear takes place)
 You need to mic. up the pistons to find out what actual clearance you have. (the pistons are undersized, probably around 50.96~97mm)
I normally set smaller Honda's at 0.0015" total clearance when boring (one and a half thousandths, just under 0.04mm)
 Tend to do everything up to 70mm bore like that, no problems so far.
CB400f is only 100cc per cyl, (51mm) so you could probably go with 0.0012" total.
PJ
Offline fmctm1sw
« Reply #3 on: March 12, 2008, 03:35:47 PM »
Thanks guys and good news, my bores look good.  I feel pretty confident with the guy.  He said the service limit would be .0012 (before I ever mentioned the specs to him) and none of mine were over .0009.  He said he'd hone them for $6 each.  I should take my pistons to him too I guess, thanks for the advice...
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
