Author Topic: CB400f/RC171 Project  (Read 5409 times)
Offline CharlieT
« on: March 11, 2008, 04:19:52 PM »
Well the retroversion got side tracked for some time. Here's the original thread on the project:
http://forums.sohc4.net/index.php?topic=20396.msg226012#msg226012
Finally getting back around to it. Been to durn cold this winter to be working out in the garage.
This is where we left off:
Had gotten the pipes all mounted up:
Had just gotten the tank and sat it in on the bike:
Now, this is what I've gotten done in the last week. Have bent and welded in some additional frame stiffeners:
Have the tank mounted up, cut of the rear frame members and made a rear frame loop/seat support and got the seat ready to mount. You can see the new frame rail under the edge of the tank
Have also got back to making the upper fairing mounts. Just need to make the lower mounts now.
Now that I have the seat and rear frame loop, can work on a couple of other things. Like relocating the battery etc up under the seat and some of the electronics in a fake oil tank. Also with the seat on it, I can finally get back to working on the proper location for the rearsets.
One thing I'm going to need to track down is some plexiglass for the fairings windscreen. Any one know of sources for some in 3mm thickness??
A good bike mechanic only needs two tools, WD40 and duct tape. If it doesn't move, but should, use the WD40. If it does move but shouldn't use the duct tape.
Offline DarkRider
Re: CB400f/RC171 Project
« Reply #1 on: March 11, 2008, 05:36:54 PM »
Why not check out the supplier that Airtech uses for the screens to go to their fairing kits? Gustafsson
www.bikescreen.com
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline tsflstb
« Reply #2 on: March 11, 2008, 08:16:16 PM »
Wow.  That is some really incredible work.  Keep this updated.
Can you still squeeze the carbs out with that extra framing?  You make me really wish I had the tools to work metal like that.  Oh, and the talent would help too.
Are you welding on rearset brackets?  I've been in the garage all night hacking out some clamp-on brackets that I'm still not happy with.  I'd like to see what you have in mind.
Offline CharlieT
« Reply #3 on: March 12, 2008, 03:12:39 PM »
www.bikescreen.com
Never heard of them. Google fairing/windscreend and all I'd get was either modern sport bikes or cruisers.
But lo and behold. I clicked on that link youb posted and Holy Repli-Racer, Batman....there it was right in their listings....a windscreen for a 1972 Honda RC172 350/4. Absolutely frickin amazing. Thanks DarkRider.
tsfl....haven't come to a conclusion on the rearsets yet. Bo have some clmap on brakets, but when I was playing around with them, I didn't have the seat yet. My suspicion is that I am going to have to weld on some brakets to get the pegs in the right position.
Offline wardmoto
« Reply #4 on: March 18, 2008, 07:41:07 PM »
Rear looks familiar....Thought about a fairing, maybe next time.
03 Suzuki SV 1000S
86 Suzuki GS 550ES
72 Honda CB 350K
72 Honda CB 350F
72 Honda Cb 350F cafe
Offline wardmoto
« Reply #5 on: March 18, 2008, 07:48:12 PM »
I messed with rear sets and scored a sweet set off e-bay and as I started mock up, I realized that the rearsets would creat more engineering problems than they solved.  not to mention, despite my form over function approach, I am 5 foot 5 inches and an old body builder (195 pounds with little fat) rearsets would fold my stubby muscular legs into painfully uncomfortable angles....stock worked great with my 4 into 4 straight meggas.  Now with my clip ons and short reach, I will need carpal tunnel surgery in short order.
03 Suzuki SV 1000S
86 Suzuki GS 550ES
72 Honda CB 350K
72 Honda CB 350F
