Author Topic: exhaust wrap  (Read 7315 times)
Offline cb650 bobber
  • Expert I ain't no stinken
  • stupid gloripope
exhaust wrap
« on: March 13, 2008, 01:42:12 PM »
So in my conteplation of wrapping my exhaust was wondering if you can buy it for a half decent price. and how much it will rot my pipes.....
"I make a point of staying right at the edge of poverty. I don't have a pair of pants without a hole in them, and the only pair of boots I have are on my feet. I don't mess around with unnecessary stuff, so I don't need much money. Von Dutch
Offline CBJoe
Re: exhaust wrap
« Reply #1 on: March 13, 2008, 05:49:39 PM »
I'm contemplating going the exhaust wrap route as well.  From what I've read, it depends on how much wet weather riding you do with regards to "rotting" or rusting the pipes.... Joe
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
Offline mark
Re: exhaust wrap
« Reply #2 on: March 13, 2008, 09:15:17 PM »
http://www.speedwaymotors.com/p/1146,47_Thermo-Tec-Header-Wrap-White.html they even have special spray paint for the stuff.
F you mark...... F you.
Offline Jim F
  • go baby go
Re: exhaust wrap
« Reply #3 on: March 14, 2008, 01:44:07 PM »
I will post some pics on a build I just finished
The wrap is a graphite color and goes with the bike scheme nicely
I will take some pics tonight
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline DrMark
Re: exhaust wrap
« Reply #4 on: March 14, 2008, 01:56:39 PM »
I purchased my header wrap thru a "HEATSHIELDS" distributor here in Iowa. I paid $38 for a 2inch - 50 foot roll in 2006. It takes about 4-5 feet per 1 foot of header pipe. They also now sell colored wrap at a higher cost. Mine is standard black.
Side Note: Soak the wrap in water first before wrapping. Allows a slight amount of stretch to the tape and when it dries...tightens up really nice. You might also notice a slight amount of stream/smoke with the first running of the bike after installation. I was told not to worry about this by other folks who have installed the same product.
I also used the stainless steel ties from Harbor Freight. Bought 20 of the 8" size for $4. Hope this helps! DrMark
1978 CB550K
1983 CB650SC Nighthawk
Offline CBJoe
Re: exhaust wrap
« Reply #5 on: March 14, 2008, 03:01:33 PM »
Can anyone confirm about whether the wrap can cause premature rusting of the pipes??  Is it weather dependent??
Joe
'65 CB77
'66 CM91 (C90'ish)
Offline Geeto67
  • A grumpy
Re: exhaust wrap
« Reply #6 on: March 14, 2008, 04:55:12 PM »
Header wrap is a textile wrap for your pipes. Where it causes rusting the most is condensation. When there is a weather change in your garage (like the kind you get from opening and closing the garage door) you get condensation (yes even a small amount). The wrap holds the condensation longer than if it just formed on the pipes and then was allowed to evaporate. If you store your bike outside you will see a lot more condensation and your bike will be exposed to the elements also.
The best way to dry out the wrap is to ride the bike - hot pipes don't hold any water to them.
I used to see it a lot on drag cars with wrapped headers - the pipes would rot out underneath the wrap and then crack.
Maintenance Matters Most
Offline LMAERO_396
  • Cafe Fighter Pilot
Re: exhaust wrap
« Reply #7 on: March 14, 2008, 07:43:29 PM »
it's been mentioned that if the headers are coated and not "bare" and then wrapped it provides a better resistance to rusting.  I plan on ceramic coating and then wrapping, one day.
*My Rides*
2002 Ford F-250 CC 7.3 Diesel
2008 HD Dyna Street Bob
1974 CB550 Project
1971 CB175 Project
fuzzybutt
Re: exhaust wrap
« Reply #8 on: March 14, 2008, 10:33:45 PM »
what kind of money would i be looking at to get a kerker cb750 header coated, theres a bunch of spots where it rusted and wont polish out. hopefully not more than a new exhaust would cost me anyways. damn kerker exhaust.
Offline Jim F
  • go baby go
Re: exhaust wrap
« Reply #9 on: March 15, 2008, 12:43:49 PM »
Here is the latest build (the Jason bike) with header wrap. ( I know its not a SOHC)
This will stay out of the weather but I would think that if you
washed the bike or got  out in the weather that the heat from the
headers would dry out the wrap soon enough as not to cause rusting
« Last Edit: March 16, 2008, 05:54:09 AM by big-jim »
Offline aj
  • no better way than goin cafe.
Re: exhaust wrap
« Reply #10 on: March 15, 2008, 11:14:42 PM »
i coated my headers then wrapped them, i keep my bike in the garage and don't ride in the rain and so far so good. header wrap is pricey for what it is mine has been wrapped about two years now i mainly did it to cover the little dings my header has.
Offline Gregorymoto
  • SOHC Aficionado
Re: exhaust wrap
« Reply #11 on: March 16, 2008, 08:24:37 AM »
Hay guys, My 2c is this, the wrap looks cool but it does rust out faster.
I would suggest ceramic coating you headers. Yes, it does cost a little more but gives you the same performance. Also with ceramic you can pic some cool colors even aluminum.
Sanderson Headers in San Francisco quoted me $100 to coat my header that was including blasting the pipe.
Good luck
Yep, i have issues with this sort of stuff.
Offline Geeto67
  • A grumpy
Re: exhaust wrap
« Reply #12 on: March 16, 2008, 08:58:48 AM »
a decent high heat paint that has been cured works just as well in preventing the headers from rusting as a high heat coating and it costs way less. If you think that hearders don't rust under jet hot coatings come over to my house and take a look at the cast iron exhaust manifolds I had jet hot coated 4 years ago. rusty as all get out. My buddy bought headers for his firebird that came with jet hot coating already on them - and it took 1 year for them to start to show rust.
remember these performance coatings and header wrap are functional enhancements before they are for looks. Header wrap retains exhaust heat to help exhaust gasses flow faster through the pipe. Performance coatings do roughly about the same with the addition of smoothing out the inside of the pipe for less turbulence as well (if you have the insides coated). I would be leery about combining these two things on a stock engine as you may be inviting more tuning to get back to optimal. On hot rodded engines that run big compression it makes sense but a little old stocker may loose a pony or two from ill placed header wrap.
Offline Gregorymoto
  • SOHC Aficionado
Re: exhaust wrap
« Reply #13 on: March 16, 2008, 11:52:00 AM »
I'm not saying you are wrong about the Hot Jet, but i think it comes down to how the pipe is prepared before it is coated.
I have not used it on a header but i know one guy that did a basic ceramic coat on a 400f header and 3 years later it still looks good. We Live in San Francisco, it is always damp and salt in the air.
Offline heffay
Re: exhaust wrap
« Reply #14 on: March 16, 2008, 11:56:32 AM »
i normally think of anything being ceramic as fragile... what's the word on that?
i have no experience in wrapping or coating but was considering it.
Offline Gregorymoto
  • SOHC Aficionado
Re: exhaust wrap
« Reply #15 on: March 16, 2008, 12:46:25 PM »
No man ceramic is hard as steel but does not react to heat and distort like steel or aluminum, you can even machen it. Ii don't have my tolerances text on me, but you should look into it. It has some cool properties.
Heii glock hand guns produced a ceramic hand gun.
Offline Geeto67
  • A grumpy
Re: exhaust wrap
« Reply #16 on: March 16, 2008, 03:23:18 PM »
most of the space shuttle is ceramic....notwithstanding what has happened in recent history that stuff has to be tough as nails to withstand earth re-entry.
Offline Helo229
Re: exhaust wrap
« Reply #17 on: March 16, 2008, 03:48:41 PM »
Dupont (I think it's dupont) makes a 1200F high-temp paint that's ceramic-based. You can pick it up at autozone/advanced auto/napa/where ever. It does have to be heat-cured, but If you clean your headers up well enough, spray them, and then run it for a few hours it should cure up fine. A good coat of that should hold up just as well as a professional job, for alot cheaper. I got a buddy who's a ricer and used it on some parts for his civic a while back and it's still holding up strong.
Offline heffay
Re: exhaust wrap
« Reply #18 on: March 16, 2008, 03:53:08 PM »
so how about a powder coat then wrap... my buddy in town that works at sun honda in denver bought the sears powder coat system... excellent results on all the parts we've done so far.
comes in cool colors as well!  may be tempted not to wrap w/ a fancy blue, yellow or red.   ;)
Offline Gregorymoto
  • SOHC Aficionado
Re: exhaust wrap
« Reply #19 on: March 16, 2008, 05:01:14 PM »
I had a header powder coated and it held up tell i got a chip in it, then it rusted and started to peal off little by little.
The wrap might protect it, who knows.
Good luck
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
Re: exhaust wrap
« Reply #20 on: March 16, 2008, 05:06:21 PM »
Ceramic coating is for heat/exhausts/etc
Powdercoating is for stuff like wheels/frames/and so on.
If you powdercoat an exhaust system, it will just be a matter of time before the color goes to #$%*, and eventually it starts to flake off. You can get ceramic coating in either polished silver or flat black, and if done right will last forever...
Just my 2cents...
Offline Gregorymoto
  • SOHC Aficionado
Re: exhaust wrap
« Reply #21 on: March 16, 2008, 05:10:16 PM »
Naa Man they make 1200f powder coat for motor parts and headers.
