Author Topic: Leaky and Smoky  (Read 1684 times)
bkalasin
Leaky and Smoky
« on: August 08, 2005, 05:49:33 PM »
Did a patial rebuild on my '72 CB750 some time ago (rings, gaskets, and seals) due to compression issues. Am now blowing what looks and smells to be gasoline from #3 tail pipe directly onto my rear wheel. After several minutes I also get smoke where pipe #3 attaches to the engine itself. Thought I had set the valve clearences properly but she doesn't sound overly efficient either. Is this my problem or do I have other gremlins? Do the rings need to seat? Carbs?- I did open them up and clean them. Why only one pipe blowing gas? Anyone care to tell me where I should start?
Offline Clyde
Re: Leaky and Smoky
« Reply #1 on: August 08, 2005, 05:56:50 PM »
I had a similar problem on my K0, where the 3 and 4 pipes were blowing fumes and gas.  The solution was to balance the carbs and the problem disappeared. The slides were much higher than those on 1 and 2
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
bkalasin
Re: Leaky and Smoky
« Reply #2 on: August 10, 2005, 03:23:35 PM »
Appreciate the information. However, upon further inspection, I noticed that the gas is NOT coming from the pipe. Rather there is a drip from the overflow pipe to the oil tank that was routed in such a way that it dropped immediately into the end of the tail pipe and turned into a fine mist coating my rear wheel. Re-routed the overflow pipe but the gas is still blowing onto my wheel and wet, sticky substances coating your wheels are a little disconcerting. So my question is now "Why do I have gasoline in my oil tank?"
Offline kghost
Re: Leaky and Smoky
« Reply #3 on: August 10, 2005, 07:07:56 PM »
Could be carb sync, but I am more inclined to think your carbs are leaking and filling the engine with gas.
Stranger in a strange land
Offline pmpski_1
  • Beast V and Beast I
    • My CB550 related blog on MSN Spaces
Re: Leaky and Smoky
« Reply #4 on: August 10, 2005, 10:48:02 PM »
kghost - What do you mean by that? How\Where do the carbs leak?
Beast   I: 1974 CB550K
Beast IV: 1976 Chevy Blazer
Beast  V: 2003 Buell XB9S
Re: Leaky and Smoky
« Reply #5 on: August 10, 2005, 11:26:04 PM »
Okay, here is how to get gas in the oil supply.
1- Fuel in gas tank
2 - Petcock on or leaky petcock valve
3- one or more carburetor float valves leaky or other wise unable to stop flow from tank.
4- overflow stand pipe in carb bowl plugged or tube attached underneath carb plugged.
5- Fuel spills into carb bore and intake runner.
6- leaks past intake valve into cylinder.
7- leaks past piston rings and drips to bottom of engine.
8a- dry sump engine has scavenge pump, sucks fuel into oil tank.
8b-wet sump engine now has gas in the oil sump.
Offline kghost
Re: Leaky and Smoky
« Reply #6 on: August 11, 2005, 07:21:23 AM »
There ya go, TwoTired answered that.
Offline pmpski_1
Re: Leaky and Smoky
« Reply #7 on: August 11, 2005, 07:34:36 AM »
Thanks, makes sense. I guess my brain was a little fried last night. Long day at work :)
