Author Topic: GASKET BRAND / QUALITY??  (Read 1800 times)
Offline chippyfive50
  • NO PEE ON TEPEE
    • thesweetimpala
« on: March 16, 2008, 08:32:49 AM »
I am about to embark on a top-end rebuild of my 750 K4.
I have seen the top-end sets / total sets in a wide price range.
Any brand recommendations other that the dealer??
SOHC Member#4000
71' 500K0 #1021237--E1108327
78' 550
72' 750K2(sold to "Craig")
74' 750K4 #2306334--E2303422
73' CL175
http://gallery.sohc4.net/main.php?g2_itemId=14013
Offline heffay
Re: GASKET BRAND / QUALITY??
« Reply #1 on: March 16, 2008, 09:12:50 AM »
its been said and i'm just gonna pass it on...
buy honda
i just purchased the complete honda engine gasket set for the 400f...  :)
Offline heffay
« Reply #2 on: March 16, 2008, 09:14:33 AM »
so, when you say dealer... do you mean honda?
... just because you don't like your crack dealer doesn't mean you don't like his crack  ;)
« Reply #3 on: March 16, 2008, 09:40:34 AM »
Heff,
so, when you say crack, do you mean his butt crack or his rock?  ;D  (couldn't resist)
Anyway, yeah Honda gaskets, etc are more expensive but in this case there is a reason why - they are worth the minimal extra expense. Considering you are/will see how much work there is to a rebuild ask yourself - do I want to do this again when I should have laid out a few more bucks the first time? Just depends on if you are keeping the bike and want to put some miles on it.
Offline heffay
« Reply #4 on: March 16, 2008, 09:43:37 AM »
i know a few plumbers who like to sling crack... i prefer to go elsewhere unless i'm really desperate.   8)
« Reply #5 on: March 16, 2008, 10:50:05 AM »
Agreed on Honda gaskets, BUT I was told just last week that a complete set (750) was no longer available. It wasn't the parts guy I usually deal with so I didn't pursue the matter. I also know that certain individual gaskets aren't available either.
We may be forced to find an aftermarket source like it or not.
Offline hymodyne
« Reply #6 on: March 16, 2008, 11:55:05 AM »
I've got an upper head rebuild and a carb rebuild in my  future, and I'm planning on getting Honda parts from my local dealer (whose prices are high enough that you'd think he was selling something else :o) but as may have said, the honda parts are worth the price.
hym
Offline heffay
« Reply #7 on: March 16, 2008, 11:59:28 AM »
maybe the 400 and bigger engines are entirely different gasket pricing but i found my set on ebay (he even included some leftover oil seals beyond the unopened complete set) for 51 dollars including shipping.
is that bad?  if it is, i need to redefine my definition of saving a buck.
Offline bert96
  • past ride
« Reply #8 on: March 16, 2008, 02:58:41 PM »
I bought a set,(the last time i rebuilt my engine) from honda because they were suppose to be better but guess what...my base gasket is leaking...this time i'll use cometic gaskets for the base and the head,for the rest i have a set that i bought from cyclex.I don't see why a lot of guys only use OEM gaskets.With cars we only use Fel-pro gasket and not OEM and we don't have any problem.When i can,i try to buy aftermarket parts,for exemple i've just buy my cable clutch and i bought MotionPro instead of OEM and i'm really satisfied with the quality.That's just my .02 cent
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Offline neil young
  • striving to be an
« Reply #9 on: March 16, 2008, 03:58:20 PM »
correct me if im wrong.....but are the honda gaskets made by Vesrah?
if so Z1 has them for the 550....not sure about the 750.
1972 CB500 k1
1974 CB550
1977 cb 550
2008 Triumph Scrambler
Offline heffay
« Reply #10 on: March 16, 2008, 04:04:55 PM »
me too... but being friends w/ gordon, i knew he would have a few choice words.
and, i knew it... when i told him i scored the gasket set from ebay he says: "honda right?!"
 ;D
Offline Jeremiah
    • North City Vintage Honda
« Reply #11 on: March 16, 2008, 07:20:56 PM »
I've used Athena gaskets on the last 4 550s and had no problems..  I think if you do it right, it doesn't matter that much.  Honda seems to have the nicest head gasket, but it's almost as much money as the complete set by versah or athena.
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #12 on: March 16, 2008, 08:07:07 PM »
I've heard good things about Athena.
On a side note, since Honda no longer makes complete gasket sets for the 350F (A or B) I added up the total if I were to buy every seal, o-ring, and gasket from Honda for the entire engine....
Came out to a little over $300  :(
 Matt.
Gallery at:
Offline mark
« Reply #13 on: March 16, 2008, 10:13:12 PM »
..........With cars we only use Fel-pro gasket and not OEM and we don't have any problem......
+1 ...... too bad they don't make Honda sohc gaskets. Fel-Pro always blamed their higher kit prices on their fancy Viton valve stem seals - what's honda's excuse? :P
I just got an Athena set for the 350 twin. The head gasket is punched from Victor/Reinz stock. V/R has put a lot into updating their materials over the past decade or so. The exhaust rings are a modern corrugated stainless/graphite composite that looks like it should be more tolerant of slightly pitted surfaces than copper/asbestos. The flat gaskets are punched from green stuff that looks like what FIAT used to use... hmmmm.
The set includes both cam cover gaskets - only one still available oem. It wouldn't bother me if they had put in some more o-rings and maybe the oil pump gasket that is also NLA............
The aftermarket oil seal kits for the twins and the 500-4 usually include the clutch lifter seal that Honda has discontinued.
F you mark...... F you.
Offline heffay
« Reply #14 on: March 16, 2008, 11:13:08 PM »
SOHC4s   :P   :)    :P
