Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
Hi Andy your bike is looking very good ,were did you get your seat from and I guess you have changed the hardware to hook and catch did the seat just bolt on or did you after alter anything?cheers Mick.
I like it both ways,
Looks great Andy. I am a little more partial to the Giuliari seat myself but man your bike is nice either way.
Quote from: CB750 Cafe Racer Fan on June 05, 2013, 08:28:51 PM I like it both ways, Too much information.....
I had a great run about 3 weeks ago going to Rhode Island for the day. Anyway get back to the K2 last night and 2+3 are not firing. Havent done any deep troubleshooting yet aside from take the tank off and check the wiring is connected - appears to be. I did notice the HT lead to #2 may be broken at the cap end so that needs investigating. But I suspect at this point its maybe the coil not working and so need to carefully check the black/white wire from coil. Just venting as its getting cooler here and this is the best riding weather - and I have a trip to Scottish Highland Games in NH this weekend!
Quote from: andy750 on September 17, 2019, 05:30:36 PMI had a great run about 3 weeks ago going to Rhode Island for the day. Anyway get back to the K2 last night and 2+3 are not firing. Havent done any deep troubleshooting yet aside from take the tank off and check the wiring is connected - appears to be. I did notice the HT lead to #2 may be broken at the cap end so that needs investigating. But I suspect at this point its maybe the coil not working and so need to carefully check the black/white wire from coil. Just venting as its getting cooler here and this is the best riding weather - and I have a trip to Scottish Highland Games in NH this weekend! Check for spark on 2 and 3 wires (pull a plug out and hold it against case and turn it over). If no spark, swap blue and yellow wires (pull all spark plug wires off). Test them again. If spark, probably something up with your points. If still no spark, coil might have #$%* the bed. Good luck
PS - I am getting closer. Have to finish a few more things then it will be ready for first start up.
What ignition are you using Andy?
