Author Topic: Fixing CB400f engine into cb350f  (Read 1299 times)
Offline yd72
« on: March 18, 2008, 09:45:39 PM »
Guys, any idea?
Can we fix a cb400f engine into the cb350f frame??
Offline cafe750
  • If you can't fix it with a hammer, it's electrical
Re: Fixing CB400f engine into cb350f
« Reply #1 on: March 18, 2008, 09:50:53 PM »
I've seen it done, I just don't know the particulars of the swap. It should fit without too much headache though.... :-\
"It's an old motorcycle, the wind is supposed to blow your head around, it's supposed to leak oil, the brakes should suck, and every now and then, it should scare you so bad you piss your pants."
Roy, Washington
Offline ttr400
    • ttr400 Projects and Billet parts.
« Reply #2 on: March 19, 2008, 09:32:35 AM »
Mounting points for the 400F and 350F motors are the same. will fit fine.
Kevin
CB400F- 492 Yoshi Racer.
Cb400F- 466 Yoshi Cafe.
CR750 D Mann Replica.
VFR750R- RC30 - 1988.
www.ttr400.com
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #3 on: March 19, 2008, 10:46:37 AM »
Guys, any idea?
Let's shoehorn a 750 in there, the 400's too easy   :D
Gallery at:
Offline mikedialect
  • cbjunky
    • Mike's Metric Vintage Honda
« Reply #4 on: March 19, 2008, 12:01:03 PM »
Guys, any idea?
and then ride in a straight line only :)
SOHC4 Member#44153
www.mikesmetric.com | www.mikedialect.com
