Author Topic: Tank dent  (Read 2027 times)
Ryan 550k
Tank dent
« on: March 24, 2008, 07:30:47 PM »
Hey everyone.  It's bound to happen to us all at LEAST once right?  I dropped my bike today, I misjudged a curve in the road.  I put a pretty nice dent in the tank and completely obliterated one of my side panels.  Other than a few good size raspberries I'm fine.....amazingly.  So, can a tank dent be repaired?  Or is it just #$%*ed and I should start looking for a new tank?
Offline greenjeans
  • 1972 CB750K2
Re: Tank dent
« Reply #1 on: March 24, 2008, 07:33:04 PM »
Well, good to hear you're ok... probably cheaper to start looking for a new tank than to pay somebody to fix it...
Re: Tank dent
« Reply #2 on: March 24, 2008, 07:35:13 PM »
It depends on the dent. There is no reason a tank can't be Bondoed and resprayed.
Offline GammaFlat
Re: Tank dent
« Reply #3 on: March 24, 2008, 07:42:53 PM »
I've been told that you put between 1 and 3 psi into the tank and gently "rubber mallet" around the dent.  If you don't care about the paint, apply heat first on the outside of the dent working your way inward.  ("tanks" HondaMan and DragMan836)
K6
K7
Suzuki GN400 - Ignition fixed!
03 KLR650 - Doesn't do anything very well but.. well.. does everything.
Offline tom8Toe
Re: Tank dent
« Reply #4 on: March 24, 2008, 09:35:50 PM »
I thought there was a thread not too long ago where someone with a dented tank filled their tank just shy of the filler cap with water and put it in the freezer. Not having done it myself, I'm not completely sure of how effective it is or if there are any concerns needing to be addressed. Unfortunately, I'm unable to find the thread now.
Anyone else remember seeing the thread I'm referring to?
-Chris-
"A model built for comfort, really built with style Specialist tradition, mama, let me feast my eyes" - Led Zeppelin
Current:
2014 Triumph Scrambler
Past Rides:
'89 Kawasaki EX500 (Crashed)
'72 BSA A75 Rocket3 (Sold)
'65 Honda CB450 Black Bomber (Stolen, never recovered)
'89 Honda GB500 (Sold)
'75 Honda CB400F (Sold)
'08 Triumph Bonneville T-100 (Sold)
'14 Triumph Scrambler
Not a valid vimeo URLpL9U0m.jpg[/img]
fuzzybutt
Re: Tank dent
« Reply #5 on: March 24, 2008, 09:42:21 PM »
Offline tom8Toe
Re: Tank dent
« Reply #6 on: March 24, 2008, 09:50:47 PM »
http://forums.sohc4.net/index.php?topic=31779.15
Thanks Fuzz. I knew I hadn't been hallucinating. However, I never can tell anymore  :D
-Chris-
Current:
Past Rides:
Offline chopstar500
  • King of the Nighttime World
Re: Tank dent
« Reply #7 on: March 25, 2008, 05:59:01 AM »
Two words: BON - DO
Completed Project "Four Pack" - My 1971 CB500 KO - Now For Sale - email me for more info!
Offline Gordon
  • 750K1, 550K2
Re: Tank dent
« Reply #8 on: March 25, 2008, 08:35:05 AM »
We never got an update after he tried it the second time.
I still don't think it's a good idea.  The freezing water will expand the entire tank, not just the dented areas, and you could very easily end up with split seams along the bottom.
Offline Donzon
  • CB750K4
Re: Tank dent
« Reply #9 on: March 25, 2008, 08:52:36 AM »
The metal is really thin.  Try to bend a bar so the end reaches the dent through the filler and tap tap tap.  Won't be perfect but it cuts down on the Bondo.
Don
Offline merc2dogs
Re: Tank dent
« Reply #10 on: March 25, 2008, 09:04:36 AM »
 Depends on the size and shape of the dent, and whether there are hard bends at the edges. Also on whether the tank is easily replaced
I've had good luck using  push rods made out of 3/4 inch or bigger steel rod with the ends rounded and bent to shape can reach most areas on a tank and let you push them out.
Also welding some disks to some thinner rod bent into eyes, or grind the heads of some carriage bolts flat, then solder them to the tank in the center of the dent and use them as puller posts, keep pressure on them and tap around the edge of the dent, that will normally walk the dent out.
 Have heard of using the same pullers with super glue to pull dents and avoiding the solder aspect, haven't tried it but plan to experiment. Need to have a larger head on them though to increase surface area.
Ken.
Offline Geeto67
  • A grumpy
Re: Tank dent
« Reply #11 on: March 25, 2008, 11:01:06 AM »
Ken.
paintless dent repair - they sell kits to do it but the kis are crappy. A pro auto body shop should have a pro-grade setup which actually works. A buddy of mine does this and I had him pull a dent out of a T500 tank for me, worked pretty good.
Maintenance Matters Most
Offline cafe750
  • If you can't fix it with a hammer, it's electrical
Re: Tank dent
« Reply #12 on: March 25, 2008, 06:23:06 PM »
Just dont get too rambunctious with using the filler neck as a fulcrum for anything you may stick in there....I tried popping out a dent, and i wound up almost collapsing the tank, because the metal is really soft. Luckily, I was able to pull it back up, and I decided to leave the little dent alone... :-\
"It's an old motorcycle, the wind is supposed to blow your head around, it's supposed to leak oil, the brakes should suck, and every now and then, it should scare you so bad you piss your pants."
Roy, Washington
Offline OldSchool_IsCool
  • Really feeling like an
Re: Tank dent
« Reply #13 on: March 25, 2008, 06:35:47 PM »
As a last resort, create a matching dent on the other side.  Ya never know... it might look good!
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline moham
  • .fnord.
Re: Tank dent
« Reply #14 on: March 25, 2008, 06:37:12 PM »
Funny, that's exactly what I was wondering to myself reading the other posts...I wonder if the others that have done this successfully have a particular technique? (I will soon be in the tank de-denting mode myself)...
78 750K-The Ocho
74 550-The Cherry Picker
70 750K0 motor-Dick in a Box
Offline merc2dogs
Re: Tank dent
« Reply #15 on: March 25, 2008, 08:49:37 PM »
use a slapping spoon in the neck as a fulcrum, keep forces aligned with the sheetmetal of the tank itself.
  The rod is primarily used to apply and maintain pressure, don't need a lot of force the actual dent removal is done by tapping around the dent with a body hammer right where it folds.
  When you hit the fold two things happen, it's restrained by the bar and surrounding sheet metal, so instead of denting in more it tends to flatten out the bend which pulls the dent out.
 When the hammer hits it knocks the bar back and since you have pressure on that, it springs back and hits the bottom of the dent and pushes against it.
 Basically you're using the hammer-off-dolly method in reverse
Ken.
Offline pablo78cb550
  • mmmph.
Re: Tank dent
« Reply #16 on: March 25, 2008, 11:52:25 PM »
i used liquid steel in the emblem mounting areas and a tiny bit in a ding.
it works really well.
Bikes in hand:
1977 Yamaha XS650
1978 Yamaha SR500 #119!
1978 Yamaha XS400
1978 Honda CB550K
1965 Ducati Monza 250
Sold off:
1992 Yamaha FZR600
1981 Yamaha Seca 550
Re: Tank dent
« Reply #17 on: March 26, 2008, 12:11:51 AM »
My last F2 tank had two holes in it where the PO had screwed a self tapping screw into it to pull a dent, then he just bondo'd over the holes. Luckily Ii stripped it before painting it, or it could have been nasty. I brazed up the holes.............
I've got a "stud welder" that I bought for $2000.00 a few years ago (but I've seen some really cheap ones on EBay or in the Eastwood Company on line catalogue) when I was painting a lot of cars in my garage for workmates on weekends.
Anyway, it's a great device, you need to strip the dented area back to bare metal of course, but then you just weld the studs into the dent and use a pair of pliers or a slide hammer to pull the dents out, then twist or grind the pins off. Still not a perfect solution, but you only need a smidgeon of Bondo. Cheers, Terry. ;D
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
Re: Tank dent
« Reply #18 on: March 26, 2008, 02:08:39 AM »
x2 on the stud welder. had the chance to use a nice one before, and have since wished i owned one for motorcycle tanks. harbor freight sells one for around a hundred, but well...it's harbor freight. if you're good enough at welding you could basically do the same thing with some small steel rod and a slide hammer.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Re: Tank dent
« Reply #19 on: March 26, 2008, 02:55:54 AM »
Offline paulages
  • 1976 cb735
Re: Tank dent
« Reply #20 on: March 26, 2008, 12:54:16 PM »
This one would probably be good enough.  ;D
http://cgi.ebay.com/ebaymotors/Dent-repair-stud-welder_W0QQitemZ110235938887QQcmdZViewItem?hash=item110235938887
"chicago electric..." that's one of the top-notch harbor freight brands.  ;)
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Re: Tank dent
« Reply #21 on: March 26, 2008, 08:47:19 PM »
No good Paul?  ;D
Offline paulages
  • 1976 cb735
Re: Tank dent
« Reply #22 on: March 26, 2008, 11:18:12 PM »
No good Paul?  ;D
i'd buy it for $30, but i usually rely on the fact that i can return my harbor freight tool when it breaks after the first use. as a matter of fact, i have a general criteria i use when buying tools from there (which is surprisingly too frequent), which pretty much can be summarized by the following question: "will i have to use this more than once?"
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
