Author Topic: Cracks in Engine Casing  (Read 4841 times)
Roscoe
« on: March 25, 2008, 04:18:54 PM »
Hey guys,
Is this a problem?
I have been cleaning off the old paint before repainting the engine for my 78 CB750 F2 and noticed these. There appears to be no gaps and no oil has been seeping out. Can I ignore them or is it a major issue? They look a bit like stress cracks.
Offline Aaron J Williams
  • Old Biker
  • Member # 725
    • Dude's Garage
Re: Cracks in Engine Casing
« Reply #1 on: March 25, 2008, 04:29:06 PM »
Not to worry, they are just casting marks from the look of them.
There are old bikers and there are bold bikers but there are very few old, bold bikers.
Quote from: Gordon
Not doing what you can to make your bike ride-able during the best riding months of the year kind of defeats the purpose of owning it in the first place.
Offline hymodyne
« Reply #2 on: March 25, 2008, 05:07:50 PM »
couldn't you magnaflux the case to check for cracks? I may be calling it by the wrong name; I had the block of my old triumph gt6 submitted to a process that exposed hairline cracks  before  I rebuilt the engine.
hym
Offline CBJoe
« Reply #3 on: March 25, 2008, 05:12:33 PM »
Here's the post about the casting marks.
http://forums.sohc4.net/index.php?topic=31143.0
Joe
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
Offline scondon
  • Mmmm......tasty bugs
« Reply #4 on: March 25, 2008, 05:27:13 PM »
 My engines have looked much the same and "cracks" were in damn near the same spot as yours. No worries, paint will hide them ;) :)
Roscoe
« Reply #5 on: March 25, 2008, 05:46:59 PM »
Thank you all very much for the replies. You have certainly taken a great weight off my shoulders. As it is for the f2 the finished engine will be satin black so hopefully it will hide the cracks. Thanks again for all your help. I don't know what I would do without this forum. Bloody glad I found it.
« Reply #6 on: March 25, 2008, 06:51:05 PM »
What is the fourth number from the right side going to the left? Is it diecast or sandcast?
Cracks like that a common on diecast later in the runs..
« Reply #7 on: March 25, 2008, 07:32:27 PM »
hym
Hym, I had a 68 GT6, fun ride.
Offline hymodyne
« Reply #8 on: March 25, 2008, 07:39:38 PM »
I rebuilt the engine and then got divorced... >:( I still have the engine. I hope to rebuild a GT6+ around it once I get this bike of mine built like I want it.
hym
Offline merc2dogs
« Reply #9 on: March 25, 2008, 07:41:25 PM »
 You normally get marks like that from a mold that's not warmed up all the way, generally morning shift stuff
 Worked at a couple diecasting shops and morning shift would throw the first few castings into the re-melt pile  because of the way the cold molds would 'crack' the castings. Mondays would be a real pain as EVERYTHING was cold, and often everything for the first hour and a half was re-melt.
 Normally not a problem as mentioned earlier.
Ken
Offline JAG
  • '74 CB750K, '72 CB500, '76 550K
« Reply #10 on: March 25, 2008, 08:04:16 PM »
If it looks like what I had, it really is no big deal, just a screw up from the factory, and seemingly the reason why they painted it..  I stripped mine all down to begin polishing, and found those lil buggers...
Can't polish it away, nor no amount of sandpaper will get rid of it. The only option I was left with was to paint that section back with ceramic high temp paint..
Cafe Racing is mainly a matter of taste. It is an atavistic mentality, a peculiar mix of low style, high speed, pure dumbness, and overweening commitment to the Cafe Life and all its dangerous pleasures. I am a Cafe Racer myself, on some days - and it is one of my finest addictions. ~H. S. Thompson~
Offline Steve F
« Reply #11 on: March 25, 2008, 08:09:00 PM »
They're probably similar to (if not the same as) "knit lines" like that which is experienced in plastic injection molding, where the material goes around an obstruction within a mold and rejoins, leaving those lines.  The material is slightly cold at the leading edge of the pour, and then has trouble rejoining with itself.  A hot mold will lessen the appearance of these lines, but slows production.
Roscoe
« Reply #12 on: March 26, 2008, 12:37:11 AM »
Its B750GE-1005159. By all that I have found out its a 1978 f2 model general export.
« Reply #13 on: March 26, 2008, 03:10:50 AM »
Don't worry about it mate, as has been said before it was common on CB750 engines, and if everybody here could look closely at their bare unpainted engine cases they'd probably see those "cracks" too. Cheers, Terry. ;D
Offline jtb
  • An unlikely
« Reply #14 on: March 26, 2008, 04:49:57 AM »
Ditto Terry and Scondon.  Mine had the same texture when I had it stripped for painting.  (77 cb750f)
1977 CB750F
1985 V65 Sabre
