Author Topic: 76 cb750 main fuse  (Read 3134 times)
Offline cijiwij
76 cb750 main fuse
« on: August 11, 2005, 08:32:30 AM »
I am having the hardest time finding 15 amp fuses. they are either too long or too short.
Can you use a 16 amp, I can find those in the right length for some reason?
Offline Steve F
Re: 76 cb750 main fuse
« Reply #1 on: August 11, 2005, 09:48:08 AM »
  How could that be a problem ???  They're one of the most commonly used fuses anywhere.  ;) Try ordering fuses in Metric Amps ;D (just kidding).  Radio Shack, Auto parts stores, hardware stores, even some gas stations stock them.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #2 on: August 11, 2005, 09:59:35 AM »
Auto parts stores
That's where I got mine and a fist full of spares as well.
Offline cijiwij
« Reply #3 on: August 11, 2005, 10:11:37 AM »
Ican find em but they seem to be short or long for the fuse bracketts..i guess its ok but ive tried 3 auto parts stores and radio shack and this is what i come up with..maybe my fuse box isnt standard.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #4 on: August 11, 2005, 10:27:13 AM »
I'm assuming when you say too long, they don't fit at all. When you say short, by how much?
« Reply #5 on: August 11, 2005, 10:49:28 AM »
Fit of the fuses does have some importance, as limiting fuse clip to fuse contact area creates added resistance and heat, which may melt the fuse.
If the only correct physical size you can find is 16 AMP, use it.  It will work just fine to protect from electrical maladies.
Offline cijiwij
« Reply #6 on: August 11, 2005, 11:36:42 AM »
long and short fit but overlap or under lap the clamps.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #7 on: August 11, 2005, 12:55:50 PM »
I don't know if your '76 uses a different size fuze or not, but the fuse for may K0 is what appears to be just a hair short of 1 inch in length. I have several, if this will fit and you can't seem to locate them, I can drop a couple in the mail to you.
Offline Jonesy
  • Shop Rat
« Reply #8 on: August 11, 2005, 07:30:28 PM »
When you're at an auto parts store, look for a motorcycle fuse assortment. I had the same problem until I noticed they had these. They were a perfect fit.
Offline cijiwij
« Reply #9 on: August 12, 2005, 07:31:30 AM »
Just got back from a motorcycle dealer and same thing..too short and too long..this is funny
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #10 on: August 12, 2005, 08:40:06 AM »
How long a fuse will it take to fit right??
Offline mgilvary
« Reply #11 on: August 12, 2005, 05:00:11 PM »
You're not alone. I just went shopping for them last week and had to try a few different stores. When I finally found some, I bought the 3 packs they had in stock.
« Reply #12 on: August 12, 2005, 07:19:27 PM »
An 8AG fuse will work. They are 1/4 x 1 inch.
http://www.action2k.com/fus8ag.htm
