Author Topic: Identifying rear brake.  (Read 858 times)
Offline Godffery
  • Godffery's Garage
« on: March 29, 2008, 12:18:23 PM »
   Dose anyone recognize this bike or rear brake set -up?  I would like do something similar (mounted on the bottom) but don't know what bike it's from. I know it's not a CB 750F
   http://gallery.sohc4.net/main.php?g2_itemId=4699
Any help would be great, thanks.
   Godffery's Garage
http://tinyurl.com/yoelqb
« Last Edit: March 29, 2008, 12:21:06 PM by Godffery »
Offline cafe750
  • If you can't fix it with a hammer, it's electrical
Re: Identifying rear brake.
« Reply #1 on: March 29, 2008, 03:24:12 PM »
I don't know where that particular setup comes from, but I do know that cycle exchange does make a similar kit.
Check it out at www.cyclexchange.net
Hope this helps!
"It's an old motorcycle, the wind is supposed to blow your head around, it's supposed to leak oil, the brakes should suck, and every now and then, it should scare you so bad you piss your pants."
Roy, Washington
« Reply #2 on: March 29, 2008, 06:47:31 PM »
2nd generation Hurst Airhart... probably late 70,s early 80,s.
Rotor may be Circle Industries......
Offline Godffery
  • Godffery's Garage
« Reply #3 on: March 29, 2008, 08:27:20 PM »
  Hummm, those parts don't sound very readily available ! ?    :-\
Thanks for the info.
« Reply #4 on: March 29, 2008, 09:12:37 PM »
You can probably get parts for the caliper.. PM (Performance Machine)...or some place that deals in flattrack stuff or vintage Flattrack..
There is a pic of the first generation H/A brake and master, on the grey bike of 736cc in the cool 750,s thread..1st page..
« Last Edit: March 29, 2008, 09:17:07 PM by 754 »
