Author Topic: "INSPIRATION GALLERY "  (Read 2271088 times)
Offline B.O.X.N.I.F.E.
  • The Stumped
Re: "INSPIRATION GALLERY"
« Reply #2950 on: September 05, 2009, 09:56:33 PM »
1974 CB550
Forever West
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« Reply #2951 on: September 06, 2009, 10:08:18 AM »
looks like there's a fuel filter on the breather hose
magista
« Reply #2952 on: September 06, 2009, 12:09:01 PM »
This is the reason I love the Aussies and their knack for complete hoonery. A 2.5 Alfa V6 stuffed into a bike:
(Forgive me if this has already been posted.)
I think it lives in the States now.
« Last Edit: September 06, 2009, 12:10:32 PM by magista »
Offline KB02
« Reply #2953 on: September 06, 2009, 12:19:41 PM »
holy crap... I like it...
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
« Reply #2954 on: September 06, 2009, 05:15:06 PM »
That bike is awesome, very well put together..... :o
  • Be careful you might get a
« Reply #2955 on: September 06, 2009, 06:07:53 PM »
Yeah, it's the most motorcycle looking car engine bikes I've ever seen. Usually when somebody puts a car engine in a bike they look weird.
Offline coldright
  • That's Ms.
  • to you
« Reply #2956 on: September 06, 2009, 08:51:13 PM »
Too bad it'll only go about 50 miles between refills.
magista
« Reply #2957 on: September 07, 2009, 11:04:18 AM »
Oh but a joyous 50 miles it would be!
In the original article the builder said that if he did it again he'd use Alfas 2.0 4 cyl as it would be a bit more manageable.
Offline cafeconleche
« Reply #2958 on: September 07, 2009, 03:41:19 PM »
« Reply #2959 on: September 08, 2009, 08:04:22 AM »
saw this at greaserama ,  i swear i've seen this on the forum before.... but if not here it is
« Last Edit: September 08, 2009, 09:25:47 AM by Spikeybike »
« Reply #2960 on: September 08, 2009, 08:10:32 AM »
one of our members bikes ....... i just love this paint scheme
« Reply #2961 on: September 08, 2009, 09:20:01 AM »
Rat 400F, you may be in luck...
 ..seeing as I am the "Master of McGyverish Machinations"..
 ..I may be able to walk you thru, building your own girder, WITHOUT a milling machine  :o
  You will need a fairly good drill press, table saw, Good router, a few other bits.  Also Alum flat bar is available in 5 inch widths, i would not go less than 5 x 3/4 ".
  Let me know if interested , I think this is doable..
« Reply #2962 on: September 08, 2009, 09:48:21 AM »
I certainly appreciate your offer and I will most likely take you up on it at some point in time. I build cabinets out of my garage for a living so I have all the things required to make jigs and mill out parts. I figured I'd just make the main sections of the fork legs out of wood and then use that as a template to form the actual aluminum legs with a pattern bit in my router. I've already done this on a small scale to make little brackets.
I was also thinking I might use Aluminum that is around 1 1/4" thick. This is going to be a bar hopper so I'd rather end up heavy and strong than week and light.
As far as the pivot points go I was thinking I would use SS axles, sealed bearings and bolt it all together similar to how hubs are done with a spacer in between everything.
I'm hoping to get the Aluminum in the next week. I'll be sure to post pics in the thread I created.
I do need ideas for the shock or spring, something with about 2" of travel and cheap.
Thanks
« Reply #2963 on: September 08, 2009, 10:10:57 AM »
You may not like the 1 1/4 price..   :(
 I wood try a thinner piece for first try for a few reasons.
 I would probably use CrMo for shafts and Bushings, for the pivots.. for several reasons..
 First, original girders used bushings.
 Second, you can buy an affordable, drill & reamer to make the bushings work.. bearings may require machine shop time.
 Key to doing this.. MAKE SURE both pcs are Dowelled together while drilling axle, and pivot holes.. the rest is just........
 "removing all the metal that does not look like the piece"
  The girder is in there, just got to carve away the outer covering.. ;)
Offline SUELZER
  • Active
« Reply #2964 on: September 08, 2009, 10:38:40 AM »
1976 Honda 550F
1993 Ducati 900ss
1979 Honda 750F
Offline MMICAFE
« Reply #2965 on: September 08, 2009, 12:59:51 PM »
found some swwet bikes and some ratty ones just miscelaneous bikes
1974 Honda CB450 super sport (sold sniff sniff) (my first bike)
1979 Honda CB650 (we have a love hate relationship)
2008 Honda metropolitan (sold kinda miss it for the gas mileage)
Offline SUELZER
  • Active
« Reply #2966 on: September 08, 2009, 02:03:03 PM »
1976 Honda 550F
1993 Ducati 900ss
1979 Honda 750F
Offline MMICAFE
« Reply #2967 on: September 08, 2009, 02:20:43 PM »
i know its pretty sweet huh i just got back from test riding the new efi enfield that my buddys dad has and he wants me to put some stuff on it for him that he is gonna order from the royal enfield website i told him go cafe or trials bike
Offline 547
« Reply #2968 on: September 08, 2009, 02:27:36 PM »
this may inspire someone
i think i saw something like this here not too long ago
this is on Flint Michigan Craigslist
j-
Offline wannabridin
  • Patience made me a
  • -Garrett
« Reply #2969 on: September 08, 2009, 02:30:33 PM »
i'm sorry, but i've seen this article before and some of the bikes in there are HORRIBLE!!.  about the only thing i enjoyed looking at was the attention on the motors, the rest was nasty.  def. an inspiration for me to NOT make my bike look like that, haha!!  if you have the rest of those pictures from the article, post them!   ;D  i hope it doesn't offend, but still, EW
« Last Edit: September 08, 2009, 02:32:16 PM by wannabridin »
Offline MMICAFE
« Reply #2970 on: September 08, 2009, 08:07:45 PM »
its all good the honda chopper forum has the article on their website
Offline CaféElite
  • 1975 CB550
« Reply #2971 on: September 08, 2009, 08:15:05 PM »
I posted pics after last years grease-o-rama, looks like he has not changed much since last year. This bike is hunting me cause I want a single sided swing arm, single shock honda twin and this bike keeps popping up. Just found out in june that my EX knows him and picked up a 400 twin off him for dirt cheap. Obviously she wont trade one of my 550's for it.. shhh wheres the love.
« Last Edit: September 08, 2009, 08:25:30 PM by CaféElite »
CB550's
Kansas City..
Religion is like masturbation, do it at home and keep it to yourself
Offline scartail
« Reply #2972 on: September 09, 2009, 01:35:27 PM »
Holy!!!
See that alternator... definitely a solution to the weak charging system.
'89 Hawk GT, newly acquired, daily beater...
'76 CB550, was my daily beater... my cafe project...
'72 Yamaha R5, newly acquired project... donated to my buddy...
'67 Suzuki T20, still working on her too... Currently in pieces...
Offline cleveland
« Reply #2973 on: September 09, 2009, 02:01:03 PM »
Do you have pics of the rest of that bike?
Offline CaféElite
  • 1975 CB550
« Reply #2974 on: September 09, 2009, 04:31:27 PM »
There is a vid in this thread somewhere if you look... just google supercharge cb750 and you will probably find it.
« Last Edit: September 09, 2009, 06:44:51 PM by CaféElite »
CB550's
Kansas City..
