The SOHC/4 World Tour is in under way.
what is the thought behind the 'exhaust bar'? for regidity/looks/gives special powers?anyone know if that is a sportster seat?
wouldnt there be a risk of... whats it called. scaving? like with the chambers in 2stroke exhaustsi have been thinking that a sportster seat would work well for my 550 cafe project. seen it done anywhere anyone?
http://en.allexperts.com/q/Motorcycle-Repair-837/1997-Harley-Sportster-Exhaust.htm
Quote from: j-conn on January 09, 2009, 05:53:08 amwouldnt there be a risk of... whats it called. scaving? like with the chambers in 2stroke exhaustsI guess not. Here's a discussion of the equalization or crossover tube. Seems to beneift Harleys especially. You'll have to scroll down a bit for the answer.http://en.allexperts.com/q/Motorcycle-Repair-837/1997-Harley-Sportster-Exhaust.htm I as used on Triumph twins, Suzuki Katana & Bandit 4 cyl, and loads of other bikes I can't think of a present. It mainly helps mid range torque On most bikes ( the ones I've cut exhausts up) there is only a smallish hole in the main pipe (smaller than the cross/balance pipe) so it also has some sound deadening effect (Helmholtz resonator probably?)PJ
JAG
Quote from: j-conn on January 09, 2009, 05:53:08 amwouldnt there be a risk of... whats it called. scaving? like with the chambers in 2stroke exhaustsi have been thinking that a sportster seat would work well for my 550 cafe project. seen it done anywhere anyone?That seat looks a lot like the one on the "pro street" 500/550 from july's bike of the month:http://forums.sohc4.net/index.php?topic=37138.msg385875#msg385875looks good on that bike IMHO
I don't usually go for this look but this one looks cool.... Mick
ok joksa you can't get away with a drive by like that; give with the details.
