Author Topic: "INSPIRATION GALLERY "  (Read 2259550 times)
Offline babyfood1217
  • The only way to drink espresso is as a
  • I miss my baby...
Re: "INSPIRATION GALLERY "
« Reply #6850 on: April 17, 2011, 10:12:28 AM »
The forks look like CB750A forks to me. They have a longer lower that the "K" forks. Triple trees and turn signal mounts also look to be from the Automatic.  IMHO...
The rear looks like a 3x16 drop-center Harley to me.  Not sure about the front rim; I've had a hard time locating a narrow (2.15 - 2.30) 40-spoke 16".  Anybody got any suggestions?  RR
I agree with RR on the rear, but I'm curious if anyone else thinks the front might be the same?  Hard to tell without a direct side-on shot, but both appear to be high-centered 16" rims.  Can't compare to the rear wheel I've got from a harley as it is a 17", but just my 2 cents...
I need help moving my project bike from Wisconsin to Seattle, WA.  Willing to pay well.  Contact if interested.
SOHC member: #438
Project: 1976 CB750K
GSXR forks, Monoshock Rear end, 836 in progress, RC51 pipes, custom frame and everything else.
Offline Ricky_Racer
« Reply #6851 on: April 17, 2011, 09:47:24 PM »
I dunno either. Does anyone know if a stock width CB750A will take a 3" rim? If so, it might be a HD rear. If not...?   RR
Offline Anti-Johnny
  • 75 cb750k
  • Poser
« Reply #6852 on: April 17, 2011, 10:05:27 PM »
I'll take three.
music
« Reply #6853 on: April 17, 2011, 10:18:30 PM »
750 A trees are same width as the others I think, I  have a set I can measure.
 I have a Honda? 16 in  rim with 110 tire I think..its off a 450 i think..has a beltdrive sprocket on it, and narrow 16 in rim, looks like a sohc 750 rim style..  I had thought of running it on the front
Offline Ricky_Racer
« Reply #6854 on: April 17, 2011, 11:37:59 PM »
Okay, Frank, are you gonna lace it onto a CB750 hub? It's 40-spoke? I hope the answers are "yes"...  When you get the tire off, measure the inside of the rim if you would. I don't suppose there's any way to id the source bike, is there?   ???  I'm still looking for a source for 16" steel  wheels.
BTW, yeah the Automatic front end looks like the same width as a CB750K and the triples are as ugly as a '78's. I thought the extra lower length might come in handy some day but I really haven't pursued the issue yet.  RR
« Reply #6855 on: April 18, 2011, 08:56:23 AM »
There was a seperate thread on that front end, I had posted to it.
 The tire looks like an old/remake? of an Avon 5.00x16, that is a tall tire with a narrow side profile, it may fit where others will not.
 Also you can grind a bit off your fork legs where the tire touches.. not recommended but if you only do it in that spot you still have 85% of the original strength.
 I will check the rim today, it is size stamped, I think. I think its Honda..being belt drive narrows it down to only a few choices even including Kawi,, then its just order oem, or from a salvage yard.
Offline sangyo soichiro
  • Tuck
  • ☢ the atomic playboy ☠
« Reply #6856 on: April 18, 2011, 10:29:34 AM »
1974 CB 750
1971 CL 350 Scrambler
1966 Black Bomber
Too many others to name…
« Reply #6857 on: April 18, 2011, 07:33:40 PM »
 Looks like a CD 175 to me.
 Ricky Racer the rim is a J 16 x 2.15, the outer width of rim is 3.12 ish. With 120 on it the wide part of tire is just under 4 inch.
 Now the bad.. 36 hole... but if you use a Yam XS 650 hub, a CB 750 rotor will bolt right on, may need a spacer
Offline greenjeans
  • 1972 CB750K2
« Reply #6858 on: April 19, 2011, 06:39:13 AM »
I've been staring at those photos for days...   I think that they are the same size tires and rims.   I originally thought they were 17's, but after searching around,
the tires definitely look like the  Avon SM Mark II.  (AV004)  I have only seen those in one size - 5.00/16    I just can't imagine these fitting between stock fork triples.
I love this bike because everything is very close to stock - I mean not much in the way of frame mods etc.   Just a loop in the rear.
I'm sure there is much that we don't see....
« Reply #6859 on: April 19, 2011, 08:09:46 AM »
They both look like stadard drop-center H-D style rims with Avon 5.00 x 16s
Offline Ricky_Racer
« Reply #6860 on: April 19, 2011, 08:19:44 AM »
Thanks for the research and info, Frank. I guess I'll play around with a H-D sixteen I've got. If the 3" rim will squeeze into a set of stock width CB750 forks, getting it into a set of GL1000's should be a breeze. Too bad it's so hard to find a 16x2.15x40....
BTW, on a set of Rickman 41mm forks, it's hard to get anything wider than the standard 1.85 Borrani in there! Not much room for playing.  :P  RR
« Last Edit: April 19, 2011, 08:22:16 AM by Ricky_Racer »
Offline ev0lve
« Reply #6861 on: April 19, 2011, 04:26:10 PM »
The poor man's Guzzi Sport. Which would be me  ;D
Still doesn't hold a candle to Little_Horse  ;)
Offline lordmember1969
« Reply #6862 on: April 20, 2011, 12:23:20 PM »
Now I want one :o ;D
1977 CB 750 SS Cafe
1977 CB 750 Basket case
1971 Mustang Grande
1928 Model A Pheathon Hot Rod
1977 Harley Custom FXE
http://forums.sohc4.net/index.php?topic=70333.0
Offline hondaface75
« Reply #6863 on: April 20, 2011, 01:43:56 PM »
+1 Ive wanted one for a while now. I read somewhere they were one of the top 10 worst production bikes though :) Thats alright with me, I like odd ball bikes :o
Offline Little_Horse
    • My cafe build
« Reply #6864 on: April 20, 2011, 08:30:59 PM »
Out of all the old bikes I have ridden though the cx has best motor for power delivery vs cc's. It pulls like a much bigger engine in the low and mid range where you normally cruise but it still feels like a 500 in the top end. All in all a great engine to build a bike from, and one of the ugliest bikes honda ever made. Its quirky too which for me translates into character.
"Little Horse Cycles" facebook page: http://www.facebook.com/pages/Little-Horse-Cycles/185809474769493
LHC is my start up cafe racer shop specializing in custom parts, bikes, restoration and recreation
The 500 builds http://forums.sohc4.net/index.php?topic=64250.0
Offline MoMo
  • Ride like you're invisible
« Reply #6865 on: April 20, 2011, 09:50:45 PM »
I have two interstate versions and find the design to be as reliable, smooth, relatively easy to work on, and economical as any Honda I've ever owned...Larry
Offline hondaface75
« Reply #6866 on: April 21, 2011, 03:21:58 AM »
well this is good to hear  :D They werent my words though. Something about the bike diving to the right when you let off the throttle? and a few other things.  Definately a bike with character either way.
« Reply #6867 on: April 21, 2011, 03:36:20 AM »
There will always be a torque reaction with an engine mounted this way, same as BMW, Guzzi, etc.
I was never a fan, but have heard these engines are bullet proof. In a stripped down state what do they weigh? It might make a great little endurance racer if that shaft could go....
« Reply #6868 on: April 21, 2011, 08:13:19 AM »
Shaft wont go without a big fight. a few of those pushrod 500 running at Bonneville.
 back to that 750, I am thinking.. maybe start looking at cruiser triple trees, they tend to be wider and they may be using a saet of one of them...
« Reply #6869 on: April 21, 2011, 04:52:27 PM »
« Last Edit: April 21, 2011, 08:30:55 PM by Retro Rocket »
Offline kap384@telus.net
« Reply #6870 on: April 21, 2011, 07:28:06 PM »
Owned a GL650I for 10+ years and there was definitely little to NO torque reaction.  Keep in mind Honda has a proven record of being more innovative than Beemer or Guzzi or really any other bike manufacturer.  Simple answer, they made the big, heavy clutch spin the opposite direction.
« Last Edit: April 21, 2011, 09:32:35 PM by kap384 »
1965 Honda CB450K0
1972 Honda CT70K1
1975 Honda MR50
1975 Honda CB400F Supersport
1977 Honda CB750F2 Supersport
1978 Honda XL100
1979 Honda CBX Supersport
1982 Honda VF750S Sabre - Adventure Bike modified
1983 Honda CX650T
1995 Honda VFR750
2016 Honda CRF1000L Africa Twin
2015 KTM 200 XC-W
1963 Suzuki T10
My 1977 CB750F restoration - http://forums.sohc4.net/index.php?topic=66779.0
My 1975 CB400F restoration -
http://forums.sohc4.net/index.php?topic=145196.msg1651779#msg1651779
'More Stock Than Not' thread - http://forums.sohc4.net/index.php?topic=90807.500
My CT70 Resurrection - http://forums.sohc4.net/index.php?topic=145221.0
Best Motorcycle Tool Ever - https://www.engduro.com
Offline Jt550
  • Is more then just a F-in
  • What have I gotten myself into...... Gotta Love It
« Reply #6871 on: April 21, 2011, 07:50:25 PM »
Gotta love the little racers...... ;D
Tyler Durden: You're not your job. You're not how much money you have in the bank. You're not the car you drive. You're not the contents of your wallet. You're not your f*<king khakis. You're the all-singing, all-dancing crap of the world.
-78 CB550k with a BIG #$%* Eating Grin-
Offline SUELZER
  • Active
« Reply #6872 on: April 21, 2011, 08:00:38 PM »
yes, yes you do. that is beautiful  :'(
1976 Honda 550F
1993 Ducati 900ss
1979 Honda 750F
Offline Jt550
« Reply #6873 on: April 21, 2011, 08:06:46 PM »
 ;D ;D ;D ;D ;D ;D ; ~ ;D ;D ;D ;D ;D ;D;D ;D ;D ;D ;D ;D
Random Cafe......
An SIXGUNS Cafetracker.... (work in progress) (he give's me the inspiration to keep moving)
« Reply #6874 on: April 21, 2011, 08:11:55 PM »
 Gotta say about torque reaction on bikes..
 I had a R 100 RT.. and I gotta say it.. you notice it the first few hours or rides... and after that......
 its just not really noticeable...
.. its all part of growing up , methinks...
