Author Topic: "INSPIRATION GALLERY "  (Read 2265212 times)
Re: "INSPIRATION GALLERY "
« Reply #9400 on: August 22, 2013, 02:42:26 PM »
You cant tell which engine by the serial numbers..?
Offline RustyOlive
  • rustyolive.com
« Reply #9401 on: August 22, 2013, 03:26:48 PM »
Hell, I'm in love with RustyOlive's CB!  THAT is definitely in my top 10.
Bahaha! Thankyou sir!
Olivia is almost done. Can't wait to rip up the streets again.
« Reply #9402 on: August 22, 2013, 03:35:06 PM »
Massive respect for Cam.  Olivia is a great example of a kick-ass, garage-built bike.  Cam modified the frame, rear shock mounts and swingarm and incorporated a substantially larger rear wheel, in addition to grafting on the modern front end.  Very inspirational!!
Offline RustyOlive
  • rustyolive.com
« Reply #9403 on: August 22, 2013, 03:45:32 PM »
Wow!! Thank you for a mad props! :)
She's been a true test of my skills, patience and wallet. Hahaha but almost done... For now. Still planning a big bore kit, but later down the road.
Took these photos this week.
« Reply #9404 on: August 22, 2013, 03:56:36 PM »
What size rim and rear tire and how did you go with chain alignment..?
« Reply #9405 on: August 22, 2013, 04:05:24 PM »
180/55zr 18.
on a 18x5.50" rim
Offset front and rear sprockets from Cycle X
Offline RustyOlive
  • rustyolive.com
« Reply #9406 on: August 22, 2013, 04:09:15 PM »
Lol. Ya. What he said. ;)
Front off set came from cyclex. Rear off set spacer i machined up.
« Reply #9407 on: August 22, 2013, 04:10:34 PM »
180/55zr 18.
on a 18x5.50" rim
RO, how tight is the fit and how much frame clearance for the chain,  Added a spacer .? 10mm?  Is that in a stock swingarm..?
Offline RustyOlive
  • rustyolive.com
« Reply #9408 on: August 22, 2013, 04:29:18 PM »
180/55zr 18.
on a 18x5.50" rim
3/8 off set front sprocket.
10mm spacer between rear sprocket.
Gives me about 6-8mm clearance between chain and frame. 4-5mm clearance between chain and tire (on a 180 tire)
Swingarm is from scratch.
« Reply #9409 on: August 22, 2013, 04:31:38 PM »
180/55zr 18.
on a 18x5.50" rim
Thanks mate, I'm doing similar things with a 750 which has slightly more room, nice to know that 10mm is all thats needed, I had worked that out by measuring but seeing it is even better.... ;D ;)
Offline RustyOlive
  • rustyolive.com
« Reply #9410 on: August 22, 2013, 04:35:40 PM »
180/55zr 18.
on a 18x5.50" rim
#$%*!! Sorry! Back track! 18mm off set in the rear!! Sorry. Brain fart.
« Reply #9411 on: August 22, 2013, 04:40:19 PM »
180/55zr 18.
on a 18x5.50" rim
If thats on a stock hub, that would put the chain line out 8mm, am i reading that correctly...?
Offline RustyOlive
  • rustyolive.com
« Reply #9412 on: August 22, 2013, 05:07:27 PM »
You are almost correct.
The swing arm is 1 3/4" longer than stock. Between the front off set + the swinarm lenght + the rear off set = straight chain line. I already had 200k on the bike with this set up. No problems and no odd wear lines on either sprockets.
« Reply #9413 on: August 22, 2013, 05:11:24 PM »
Cool, thanks.... ;)
Offline DORIGTT
« Reply #9414 on: August 22, 2013, 05:31:01 PM »
What is it like to ride...cornering handling vs. straight-line?  I would like to do something similar, but I know a lot has to be done to make it 'right'.  Yours looks the part though.
Also, why size front tire/wheel are you running?
Thanks.
Offline crazypj
  • I'm brill, me
« Reply #9415 on: August 22, 2013, 06:37:45 PM »
They got all sorts of parts swapped, between years when racing as there are at least 3 different 'factory' motors
I got into XS pretty recently (about 10myrs ago) mine have Honda CR500 connecting rods, XV750 pistons and are 800cc
Offline RustyOlive
  • rustyolive.com
« Reply #9416 on: August 22, 2013, 06:56:38 PM »
Thanks.
The bike rides amazing. Tracks smooth and straight on the highways. Weaves quick and nibble in the city streets. The rear shocks are from a early 80's honda XL500. They have lots of travel and a bit softer than the stock 550 shocks. Combo with the fine tuning on the cbr forks. I can really make the bike ride smooth or agressive to my liking. I do plan to swap the rear shocks out with some more modern progressive/adjustable ones. But for now, she rides lovely. ;) lol but I could be a bit biased .. Hahaha.
Offline crazypj
  • I'm brill, me
« Reply #9417 on: August 22, 2013, 07:10:47 PM »
Are the XL500 shocks something like 15-1/2" long?
 Doesn't look 'jacked up' at rear though, maybe camera angle or is it really pretty level?
Offline RustyOlive
  • rustyolive.com
« Reply #9418 on: August 22, 2013, 07:29:33 PM »
Ya. Their either 16.5 or 17" ... Forget off the top of my head.
The rear swingarm is a 1 3/4" longer. The shock mounts on the frame are almost 2" forward on the frame from stock position. Over all, the stock 550 shocks were much to short... I'd personally like to bring the rear down another 1/2".. I'll be taking that into consideration in purchasing the next shocks. For now I'll live with it.
« Reply #9419 on: August 22, 2013, 07:44:40 PM »
I dont think the 750 frame will give those frame clearance numbers that that bike got..sorry but you would have to put a D section in or a dogleg..
Offline RustyOlive
  • rustyolive.com
« Reply #9420 on: August 22, 2013, 08:27:49 PM »
550 and 750 frames are the same width apart. I ran a 750 swingarm in the 550 before. Exact fit. It will work.
Offline RustyOlive
  • rustyolive.com
« Reply #9421 on: August 22, 2013, 09:09:02 PM »
Perhaps this 750 build will through some insight to the idea/inspiration.
http://forums.sohc4.net/index.php?topic=65268.0
« Reply #9422 on: August 22, 2013, 09:09:56 PM »
Besides, I've had big wheels sitting round for a few years now and they do fit, I was just curious to what sprocket offsets you were using.... ;)
« Reply #9423 on: August 22, 2013, 11:20:01 PM »
That's a monster.
Offline Sparked
  • Cheaper then therapy
1972 CB350F
1982 CM450A
1961 Ford Falcon (time for four wheels)
