Author Topic: "INSPIRATION GALLERY "  (Read 2388514 times)
Re: "INSPIRATION GALLERY "
« Reply #9550 on: November 03, 2013, 03:20:45 PM »
Long forks do not define a chopper..it helps but stance srsting position and other things come into play..i had a short fork chopper...
Offline Tintop
« Reply #9551 on: November 03, 2013, 03:40:51 PM »
Bobber with identity issues would be my description.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline CaféElite
  • 1975 CB550
« Reply #9552 on: November 03, 2013, 07:15:25 PM »
Agree..
« Last Edit: November 03, 2013, 07:20:40 PM by CaféElite »
CB550's
« Reply #9553 on: November 03, 2013, 07:53:17 PM »
Ok I got to mention, when it was built very few people uttered the word bobber was really only reserved for speaking about the origins of chopper.. But that was in 83 I think the seat was cut back, we made the back fender, I made up the bars.. It was all chopper stuff.
 Actually I bolted. A steel plate to the stock triple tree bar mounts, then welded two bent bars betweem the plate and a set of drag bars..
 Bike is still rumoured to be around, would love to get it back..
Offline SF
  • I burn gas very well
« Reply #9554 on: November 03, 2013, 08:02:29 PM »
As for that MH550J; It dose have a cut out of the tail section for tire clearance:
That being said, I'm not convinced it still wouldn't hit on a good bump.?
Godffery,  where can I see more of this bike?
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
« Reply #9555 on: November 03, 2013, 09:56:52 PM »
I like that red bike Frank, its well balanced ..... ;)
Offline Godffery
  • Godffery's Garage
« Reply #9556 on: November 03, 2013, 11:24:25 PM »
Here you go:
 http://www.motohangar.com/mhCustoms.html
Offline apetersonboy
  • 1978 CB 750F SS
  • Slow and not very steady.
« Reply #9557 on: November 07, 2013, 11:58:04 AM »
You sure looked different back then!
« Reply #9558 on: November 07, 2013, 12:23:40 PM »
 ;D ;D ;D :o
Offline Ricky_Racer
« Reply #9559 on: November 07, 2013, 12:47:12 PM »
Frank, you might know the answer to this question: Did Amen make CB750 Savior frames with different steering head rakes? The one in your photos uses standard fork tubes and yet most of the Saviors I've seen run extended tubes. Did you derake the steering head?
The reason I ask is that I have a couple Savior frames and they seem (unverified as yet) to call for about a 6-over. I think I'd like to build one up but I absolutely hate extended tubes, even with a 21" front hoop. I think that extended tubes make the front wheel look awkward, and I'd rather not run a springer if I can get an Amen to run level with standard tubes and dual disks.
Thanks in advance. RR
« Reply #9560 on: November 07, 2013, 10:28:52 PM »
You may have been able to order different rake, but never seen them advertise it, that I remember.
My red bike had I think 8 overs on it, before I decided to lower it.
 Keep in mind you need very tucked in drag pipes or a high pipe, and iz relocated the side stand
 Rake may be less than 10 extra after lowering it, I suspect more like 6 or 7..
Go for it, you will like it..
Offline Ricky_Racer
« Reply #9561 on: November 08, 2013, 08:21:56 AM »
Thanks for the reply, Frank, but I could use a little additional info... How did you lower your red Savior? Those look like stock forks.
I've looked closely at 1054's old black Amen and his forks look to be around four to six over. Not too bad at that length. Thanks again. RR
« Reply #9562 on: November 08, 2013, 09:32:35 AM »
They were in fact genuine Honda 77/78 hardchrome forks in 73 legs.
 I cut of the sidestand mount then moved it behind the shifter cover, you can see it in the pic on this page.
 We will do the same on the other one, the rigid.
 You need tucked in drag pipes, or a high pipe. If forks are a bit o
Longer you can run some 4-1.. Like RC.. Fits.. But others like Hooker, had to splice about 1 1/4 inches inthe 4 headpipes, for collector to clear frame
Offline Ricky_Racer
« Reply #9563 on: November 08, 2013, 10:33:05 AM »
Okay. Got it, Frank. So you picked up an inch with the later tubes. No problem on the drag pipes; got a set on the shelf. I've also got a set of the the old chrome Amen triple trees laying around, so I may try a set of extended tubes and then slide them down until the chassis sits right. Then at least I'll know for certain what length I need.
Just trying to decide whether to do one of the Saviors or to do a rigid, if I do a chopper at all. At this point, I might be getting a little long in the tooth for either but it'd be kinda fun to have a light "bar hopper" toy for a change of pace... Sure as heck can't make a living on CB750 chopper builds these days!  :-\
Anyway, thanks again. Have a good weekend! Ted
« Reply #9564 on: November 08, 2013, 10:59:40 AM »
This one will get sidestand on side, and he will build a highpipe..
77/78 tubes are same length as 69_76.
« Last Edit: November 08, 2013, 11:04:15 AM by 754 »
Offline Ricky_Racer
« Reply #9565 on: November 08, 2013, 01:36:00 PM »
Hmmm... Shortish Ceriani forks and long front frame tubes. And it still works. That's good news. Maybe one of my frames will take standard tubes after all. Gotta check 'em.
Lots of potential in that bike. I assume the "high chair" seat is going away!  :o  RR
« Reply #9566 on: November 08, 2013, 02:14:08 PM »
I sold a set of old CR31's this week to a guy that races bikes in historic racing here in Australia, he sent me a picture of his latest incarnation its a piece of art and all work is done by Jerry, the head was welded up and completely redesignes and he made the whole front forks except for the triple clamps, he's a very talented man... :o
Offline Ricky_Racer
« Reply #9567 on: November 08, 2013, 02:35:28 PM »
Exceptional! RR
Offline MoMo
  • Ride like you're invisible
« Reply #9568 on: November 08, 2013, 02:44:04 PM »
very niiiiiiiiice.  thanks for posting Mick
Offline SF
« Reply #9569 on: November 08, 2013, 06:48:48 PM »
front fender is nice and low!
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
Offline Doctor_D
« Reply #9570 on: November 09, 2013, 03:58:02 PM »
Wow.  I love bikes where nothing looks unusually modified or out of place, yet everywhere I look something smart has been done to it.
If he has a write-up on the bike, I'd love to see it.
« Last Edit: November 09, 2013, 04:29:00 PM by Doctor_D »
Take care,
David
1978 CX500
1971 Norton Commando
« Reply #9571 on: November 09, 2013, 04:05:53 PM »
I he has a write-up on the bike, I'd love to see it.
Yes it would be a good read. I will ask... ;)
« Reply #9572 on: November 09, 2013, 09:39:38 PM »
The engine is a CBX400. One upgrade is the ignition has been re-engineered to run behind the cylinders, no small feat.
It is a very cool racebike Mick.
« Reply #9573 on: November 10, 2013, 01:17:47 AM »
Yes it is Brent, I'm going to get Jerry to send me some pics with the fairing he made from scratch..... 8) ;)
« Reply #9574 on: November 10, 2013, 08:09:23 AM »
How about the frame and on & on.  8)  I have other pics that Jerry sent but I don't know how to move them.
Jerry checks in here, that's how he found out about your carb parts, maybe you can convince him to give an
update.
