Author Topic: help!!!!cb750a  (Read 4086 times)
cb750a
help!!!!cb750a
« on: March 31, 2008, 06:01:18 PM »
got a cb750a 1977 i ride to the tune of 10k miles a year the last 2 years my problem lies int he brakes is there any way to conver the rear to disk brake instead of drum with bolt on parts and where can i get some wheels like the comcast wheels that will bolt right on
      thanks in advance mark phillips
cb750a
Re: help!!!!cb750a
« Reply #1 on: March 31, 2008, 06:01:56 PM »
feel free to e-mail me at racer77mp@yahoo.com thanks mark phillips
Offline mystic_1
  • 1970 CB750K
Re: help!!!!cb750a
« Reply #2 on: April 01, 2008, 09:43:36 AM »
Cycle Exchange sells a drum-to-disc conversion.  Not sure but I don't see why it wouldn't work on a 750A.
mystic_1
- John Augustus Shedd
Offline eurban
Re: help!!!!cb750a
« Reply #3 on: April 01, 2008, 01:28:25 PM »
The 77 and 78 750F models (F2s&F3s) come stock with comstar wheels, dual discs up front and a disc rear.  I am not sure why you are focused on the rear wheel as the vast majority of your braking power should be up front.  Regardless, if you want to install comstar wheels on your auto and to significantly upgrade your brakes, your best bet would be to get a f2/f3 front end complete with forks, calipers, rotors, wheel and master cylinder.  The forks would slide into your stock triple trees.  On the back for a disc brake, you would need the F2/F3 swingarm, master cylinder, rear wheel, rotor, and proabably the brake pedal.  You could also go for a comstar drum brake wheel on the back by using a 78 autos rear wheel. . . .By the way, your spoke wheels (assuming they are stock) are pretty nice pieces as they have lightweight  aluminum DID rims.  You could probably sell them to help offset the costs of the F2/F3 parts.  . . .IMHO Comstars significantly detract from classic good looks of our bikes and swapping to them is a move in the wrong direction.  They are also not all of a tubeless design (I am pretty sure the F2/F3 wheels are not tubeless).
Offline eurban
Re: help!!!!cb750a
« Reply #4 on: April 01, 2008, 01:40:20 PM »
mystic_1
The cyclex setup sure looks cool but it is pretty expensive particularly when you add the cost of the master cylinder and fabricating involved.  Also its got to be heavier than hell.
Offline mystic_1
  • 1970 CB750K
Re: help!!!!cb750a
« Reply #5 on: April 01, 2008, 02:57:05 PM »
Yup, I agree, but it's the closest thing to a "bolt on conversion" that I know of.  Can't be much worse, price-wise and fabrication-wise, than replacing the swingarm, m/c, wheel, and brake pedal.
BUT I also agree that improving the front brakes would be a much better investment.  Even with the stock drum brakes it's pretty easy to lock up the rear wheel on a 750.
mystic_1
cb750a
Re: help!!!!cb750a
« Reply #6 on: April 01, 2008, 06:37:08 PM »
well first let me say thak you guys for al the info after 2 min of carefull consideration and a beer i decided to stick with the spoke rims would like to find some that are all chrome spokes and hubs too and anyone know where i can get a complete 750 f front end? and im ok with the rear drum brakes just wanted to upgrade to disk to be a little more differant not that i dont get alot of what the hell kinda bike looks already riding the ol hondamatic around lol again thaks for the info and if anyone has any of the parts from the f model hit me up im in the mood to buy parts lol its almost warm here lol
cb750a
Re: help!!!!cb750a
« Reply #7 on: April 01, 2008, 06:39:58 PM »
o yeah forgot did the 750 f come with a spoked wheel?
thanks again... mark
Offline UnCrash
  • Pass
    • My Blog
Re: help!!!!cb750a
« Reply #8 on: April 01, 2008, 06:57:39 PM »
The CB750F came with spoked wheels in '75 and '76
Offline eurban
Re: help!!!!cb750a
« Reply #9 on: April 01, 2008, 07:18:49 PM »
The 75 and 76 fs came with spoked wheels.  The front used a single K bike style front rotor and caliper basically the same as your spoked auto front brakes.  There is no advantage to using this front end on your auto.  The rear is a disc brake setup and could be adapted to use on your auto if you want a spoked rear wheel with a disc brake.   As I mentioned, the 77 and 78Fs use comstar wheels with dual discs up front and disc rear.  You might find the parts you want here in the classified section on Ebay.
cb750a
Re: help!!!!cb750a
« Reply #10 on: April 01, 2008, 07:36:55 PM »
eurban honest oppinon what do u think about comstar wheels on my ol a if they was chromed that was my original plan ... again thanks ....mark
