Author Topic: guitar kit  (Read 3303 times)
fuzzybutt
guitar kit
« on: March 31, 2008, 06:43:31 PM »
have any of you guitar people ever purchased a luthiers kit from these people? or perhaps one like it?   http://cgi.ebay.com/ELECTRIC-GUITAR-KIT-Customize-and-make-your-own-guitar_W0QQitemZ260226014440QQihZ016QQcategoryZ41406QQcmdZViewItemQQ_trksidZp1742.m153.l1262 i want an inexpensive electric and this looks like it might be the way to go, since i do want a les paul style. i'm thinking of doing a high gloss tung oil for a finish.
Offline neil young
  • striving to be an
Re: guitar kit
« Reply #1 on: March 31, 2008, 09:20:49 PM »
i havnt....but i think this looks pretty good.
you seriously mulling it over?
1972 CB500 k1
1974 CB550
1977 cb 550
2008 Triumph Scrambler
fuzzybutt
Re: guitar kit
« Reply #2 on: April 01, 2008, 12:31:21 PM »
i am, i really dont have extra money to spend on a guitar right now but i really want to get back into playing. they have a telecaster kit for 95 dollars i believe. the les paul kit i was looking at went over 100 dollars which is my spending limit.
Offline Burke
Re: guitar kit
« Reply #3 on: April 01, 2008, 12:58:01 PM »
I would be wary about the pick ups.
Although you could alway get "PAF" pickups if your really geared towards the Les Paul sound.
75modrat
Re: guitar kit
« Reply #4 on: April 01, 2008, 01:19:14 PM »
I dunno, the "mother of pear" inlays may not work out so well. It seems like pear is too soft of a material and wont look good either. If it were pearl I would jump on it! okay, not then either. I know I am not very good at guitar but I know I want to buy something that is gonna last. I do believe you can buy some items cheap and modify it and you will be fine. electric guitars are that way. You can always buy some new pickups and tuning machines but sometimes I really question items like this. Sure, you save on price because you assemble and paint it but who makes it? How do we know how well they bonded the pieces of wood that make up the body. It just seems too risky. Why not try a name brand used guitar? And personally, I like the little mom and pop shop that cut you a deal just because you have been in there enough times rather than a big chain. Although I did get a great deal on a Crate Blue Voodoo 4x12 cabinet when Mars Guitar when out of business.
Just my 2 cents.
Frank
Offline DarkRider
Re: guitar kit
« Reply #5 on: April 01, 2008, 02:05:55 PM »
Now this would be something i may consider as well..but then again i do have a stratocaster copy that i may just redo soon. mostly needs a new paint scheme and machine heads.
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
Re: guitar kit
« Reply #6 on: April 01, 2008, 03:04:04 PM »
I purchased a Strat kit 4 years ago.  The neck, pickups and hardware is made by Fender while the kit producer made the body.  Not bad for $99.00.  I did not do a very good job with the lacquer (it is blocking) and am in the process of stripping it, upgraded the tuning machines, will upgrade the top nut and am doing/will do some modifications based on how Ibanez builds theirs.
edit: Am considering Dupli-color's Metalcast MC-101 Blue this time around, painting just half of the body on a diagonal.
« Last Edit: April 01, 2008, 03:09:17 PM by kslrr »
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline DarkRider
Re: guitar kit
« Reply #7 on: April 01, 2008, 03:55:05 PM »
So in the end with the strat kit..you have a stratocaster with an aftermarket body essentially?
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline tramp
Re: guitar kit
« Reply #8 on: April 01, 2008, 05:37:43 PM »
the fake wood top is a big giveaway that the kit is not  good quality
would have to see the pickups and switches
setting the neck is not easy
setting the rear bridge should be done by someone who knows what thier doing
good luck if you do it
might be better buying a elcheapo and work from there
sometimes a elcheapo plays well when set up properly
1974 750k
Offline Steve F
Re: guitar kit
« Reply #9 on: April 01, 2008, 07:19:46 PM »
Why don't you try building one of these?
Offline 333
  • Time for change
Re: guitar kit
« Reply #10 on: April 01, 2008, 07:51:12 PM »
I'm with 75Modrat, pear is no good..  I'd also stay away from anything that is "compatible" with another guitar.  "Comparable" yes, compatible- no.
The real reason to not consider it is that a Les Paul is a "hollow body" design, and judging from the pics, it looks like a solid chunk of wood.  So the sound will never be comparable or compatible with a Les Paul.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Re: guitar kit
« Reply #11 on: April 01, 2008, 11:13:06 PM »
What??
The Gibson Les Pauls have always been solid bodies, as were all the true copies.  The "real" Pauls had a maple carved top bonded to a mahogany base.  They are quite solid, apart from routes to contain the controls, pickups, and switch.  Damn heavy, too, which gives them the famous sustain.
I have a few Les Pauls.  I also have an old Guild M-75 Bluesbird that IS hollow, otherwise shaped very similar to the Les Paul.  The resonant cavity of the hollow guitar is very difficult to control feedback from the amplifier speakers.  The speakers resonate the cavity, the cavity resonates the bridge piece, which vibrates the string, which the pickup sends to the amp for amplification, and the speakers send back to the hollow body.  The M75 is a wonderful playing guitar, but a nightmare to control at higher sound levels, as teh string it vibrates are not always the string wish to play.
The Les Paul only does the amp feedback thing if the speaker gets close enough to the string to make it vibrate directly.  Best be wearing ear plugs, though.  You need a lot of amp volume to do that.
The "mother of pear" is a misprint.  Perhaps for the April Fools out there.  Mother of pearl is for the fret inlay position markers.
The kit can make a decent guitar for someone with the right skill to complete.  Setting the neck properly will be the hardest task, and getting the finish decent will also be tricky for the unskilled.  Filling the nut and and bridge notches takes unique tools.  There is no instructions with the kit, so you will need to get some books to help with that.
http://www.stewmac.com/
These people have everything you need make or complete a guitar, including the proper tools.
Don't underestimate the task of setting up the guitar for proper playability and tone production.  These are craftsman skills that do not come "naturally".
Offline azuredesign
  • Knupping pin
Re: guitar kit
« Reply #12 on: April 02, 2008, 12:51:20 AM »
What??
I agree here. Actually the kit looked sort of cool. My biggest bug with pre-made parts is neck stability. Most well made guits use wood that is dried in a controlled way, nowadays in a digitally controlled kiln, to control shrinkage and to ensure stability. With these kits, I think it's going to be hard to tell what you're going to get. Green maple has a fair amount of water in it, as any one who burns firewood can tell by hefting and comparing a green and seasoned piece. It would suck to put together a set neck guitar, and then find out the neck was unstable, creating myriad tuning and playing problems.
I also agree that Dan Erlewine and Stew Mac in general, is a very good source for materials and luthier tools, but have not been impressed by their kits too much in the past. Perhaps they are better now. One source for inexpensive, but well made necks for bolt ons is All Parts. I would also suggest looking for a used Warmouth tele neck on ebay, but either will cost closer to $200. For a cheap but cool Tele, consider trying to track down one of the Squire '51 Teles that Fender stopped making last year. They were about $125. new and should fit your price range used.
If you want to, pm me with any other questions, and I'm glad to help.
All best,
Ben
Offline kslrr
Re: guitar kit
« Reply #13 on: April 02, 2008, 10:35:25 AM »
Yea, basicly.  In addition to a recessed tremelo bridge pocket (like Ibanez), a steel ball top nut (Fender) with string locks (like Ibanez) and the neck head not shaped like a Fender, I added an in-phase / out-phase switch that effects the pickup switch positions 2 and 4.
        1981 CB650 engine
Then 1972 CL175
        1964 Yamaha YGS-1T
fuzzybutt
Re: guitar kit
« Reply #14 on: April 02, 2008, 12:07:05 PM »
is it possible to turn a strat (squier) to a hardtail. i hate the problems of keeping a guitar with tremolo in tune. i'd buy a squier strat in a heartbeat if i could either get one with a hardtail or the possibility of converting it.
Offline kslrr
Re: guitar kit
« Reply #15 on: April 02, 2008, 01:13:02 PM »
Yes, you can buy a Tele style bridge by All Parts.  Go to Sam Ash.  They have a pretty good selection.  How to mount it is another question dealing with the hole in the Strat body.
        1981 CB650 engine
Then 1972 CL175
        1964 Yamaha YGS-1T
Offline 333
  • Time for change
Re: guitar kit
« Reply #16 on: April 02, 2008, 01:55:33 PM »
I stand corrected.  I was basing my comments after seeing a PBS show on the man himself.  In it, he shows some of the prototypes he made(at this point I assume during the design of the pick-ups) which were hollow.  I'm sure that while watching, I also had my nose in the SOHC forum.  That'll teach me to only concentrate on one love at a time.
Re: guitar kit
« Reply #17 on: April 02, 2008, 02:12:37 PM »
i have a Squire bass , and i hate it , it sounds metallic. like a robot's inside of it making the noises
just thought you should hear both sides of the spectrum
Re: guitar kit
« Reply #18 on: April 02, 2008, 02:18:11 PM »
Have you tried different strings?
...Or , not using a peso as a plectrum?   ;D ;D
Offline azuredesign
  • Knupping pin
Re: guitar kit
« Reply #19 on: April 02, 2008, 03:39:42 PM »
Aw, c'mon a peso should sound cool!
I have two thoughts for you Fuzzy. First is to screw the bridge plate down flat on the guit by tightening all of the 6 screw that are in front of the bridge saddles. In addition, I don't know how many springs you're running, but the more the merrier and tight down the claw that screws the springs to the body as much as you can. That will block the tremolo pretting much. As an alternative, Hipshot makes something called a Trem Setter that will stabilize the trem bridge. Stewart Macdonald sells them, and I'm sure you can find them elsewhere as well.
The alternative is to make the trem stay in tune. This is usually a function of the nut, and how the strings run into the bridge plate, rather than a mis-function of the tremolo itself. If you find that your guitar goes sharp on you when you use the bar, the strings going sharp are most likely getting hung up on the nut notches(no laughing here). You can use a very small file( a needle file also available from Stew Mac) to widen the nut notch a bit so the string runs through easier and doesn't get hung up. Common sense dictates not cutting the nut too much deeper or you may end up with open string buzzing, just widen it. Then use some graphite to lubricate the nut notches. This is all taking for granted that the neck is fairly straight and the truss rod is adjusted correctly. If it is still playing sharp, check where the string goes into the bridge plate. Sometimes the plate has an edge that catches to wound strings and will hang them up on returning to pitch. These edges need to be rounded, either with a round file or a Dremel. There's an article somewhere on line about how Stevie Vaughan's guitar tech used to to it with photos. The other thing to keep an eye on is the string retainer(s) on the headstock, as sometimes these will keep the strings from returning to pitch.
My biggest problem with Strat trems was when you broke a string, and the bridge plate was not flush on the face of the guitar( so you could pull the tremolo sharp.) When the string broke it would really go out of tune. My old friend Craig Jones somehow figured out a way that if the high e broke it would take the guitar down a half step accurately so he could finish the song without stopping. I am not that good a tech and will never have the patience to become that good, but I guess it's possible.
Hope this all helps somehow,
Ben
fuzzybutt
Re: guitar kit
« Reply #20 on: April 03, 2008, 08:00:05 AM »
well, i ended up getting one of these, after reading all the reviews on different sites i thought this might be a decent cheapie to get back into playing with.
http://www.musiciansfriend.com/product/Dean-Evo-XM-Electric-Guitar?sku=519795
Offline azuredesign
  • Knupping pin
Re: guitar kit
« Reply #21 on: April 03, 2008, 02:25:38 PM »
Amazing what you can get for $100. bucks these days.
Enjoy!
Offline GoatBaSS
  • Could someone find an
  • To weird to live, to rare to die.
Re: guitar kit
« Reply #22 on: April 03, 2008, 02:43:49 PM »
Dean builds good stuff and they are rugged.
As for the squier bass, the pickups may have gone microphinic. I knew a guy that had one you could yell at the pickups with some a mazing results. That and a electric razor and you had a party!
If you are wanting to build, as I have done in the past, I have traded with guys @ stores, Harmony Central, thrift stores, and of course the bay and have the guitar I will never part with. It is a bastrdcaster, but If any major inst mfg ever made what I wanted at the right price, I would not have to have built it in the first place. It sometimes takes a lifetime to find the one that fits.
Good luck and keep playing! You can always build dexterity, unplugged on the couch, when you are relaxin in front of the TV.
Leethal # 3046?
1972 CB750K/900CC Red Headed Dunstall, 1975CB750FSS Gone BNF: 1974CB500T, 1976CB750K X 2
fuzzybutt
Re: guitar kit
« Reply #23 on: April 03, 2008, 05:07:34 PM »
i may end up building "the" guitar one day. i would trade my left nut for a jazzmaster. i love the look and that "surf" sound. that or a ventures model mosrite, i played one in a surf punk band back in the 80's. oh yeah, i picked up a marshall micro stack at a local pawn shop for 125 bucks, with the footswitch.
Offline dustyc
  • I don't know why anyone would call me an
  • 1977 CB750K
Re: guitar kit
« Reply #24 on: April 03, 2008, 05:40:17 PM »
You did what I was going to suggest.  That is -Just get a cheap guitar.  Cheap guitars of today are alot better than cheap guitars of the 60's and 70's.  Computer controlled routing makes for alot more controllable output.
That kit looked like alot of work for something that most likely wouldn't end up being what you're after.
For messing around, a cheap guitar should sound fine.  After all, you're probably going to be playing through a practice amp, right?  (The madness begins.)
1977 CB750
