Author Topic: I agree With The Rear Window Sticker On A Durango Today.  (Read 11552 times)
Offline Gordon
  • 750K1, 550K2
Re: I agree With The Rear Window Sticker On A Durango Today.
« Reply #100 on: April 08, 2008, 10:09:02 AM »
Make sure to use some in-line fuel filters, and for God's sake man, ditch the points and install a Dyna-S!!!
Oh, and do you carry a handgun when flying?
Offline Gordon
  • 750K1, 550K2
« Reply #101 on: April 08, 2008, 10:11:48 AM »
........and what are you using to lube the chain?
I could see a Scott-Oiler mounted to a jet, spewing oil all over the countryside as it flies over! ;D ;D
« Reply #102 on: April 08, 2008, 10:12:05 AM »
Don't forget to chop the plugs
Offline Gordon
  • 750K1, 550K2
« Reply #103 on: April 08, 2008, 10:19:13 AM »
How much is that plane worth? :-X
Offline gregimotis
  • poet laureate; SOHC4.
« Reply #104 on: April 08, 2008, 10:25:59 AM »
3.25  Unless it's painted by Von Dutch.
Offline Gordon
  • 750K1, 550K2
« Reply #105 on: April 08, 2008, 10:28:15 AM »
And if it is, does the value go down?
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
« Reply #106 on: April 08, 2008, 10:33:05 AM »
Less oil being spewed than when they flush the toilet. ::)
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
« Reply #107 on: April 08, 2008, 10:40:05 AM »
Should it have Pods or Stock Airbox
Offline kghost
« Reply #108 on: April 08, 2008, 12:57:37 PM »
Try 4.5 million. Course it depends on the engine times/cycles and the avionics package.
Straight falcon 20's are anywhere from 700,000 to 900,000 as they use the GE CF-700 engine.
Best Oil? Mobile Jet II  or 2380  ;D
Tire selection is limited as they have to be FAA certified Goodyear works for me.  ;D
No need for a plug chop....Once ya light the fires it stays burning  ;D
Best fuel? Jet-A...modified Kerosene  ;D
Stranger in a strange land
Offline mark
« Reply #109 on: April 08, 2008, 01:05:27 PM »
What's a gallon of Jet-A going for these days?
F you mark...... F you.
eldar
« Reply #110 on: April 08, 2008, 01:32:13 PM »
What jets do I use if I change the exhaust?
Offline nickjtc
« Reply #111 on: April 08, 2008, 01:39:18 PM »
....and what brand of muffler bearings are best.....?
1977 Suzuki GS750
« Reply #112 on: April 08, 2008, 01:46:54 PM »
One would hope.   ;D
Offline nickjtc
« Reply #113 on: April 08, 2008, 01:49:17 PM »
Unless they don't fill 'er up when they are supposed to and it ends up like the 'Gimli Glider'.
1977 Suzuki GS750
Offline SEBNN
« Reply #114 on: April 08, 2008, 04:04:15 PM »
That should read "fill 'er up as much as they are supposed to".  With the Gimli they miscalculated and put in too little (just as bad), otherwise that plane has range to spare on a full tank.  Either way, gliding in with that kind of beast has got to suck.
