Author Topic: Chain removal question  (Read 1094 times)
kevio
« on: April 02, 2008, 02:45:08 PM »
I did a search and didn't see anything.  Nor did I see anything in the shop manual.  I'm showing my newbie status  :-[ ... do I need to remove the front sprocket to remove the chain or do I need to pop a link?  I have the entire bike stripped down to the frame and engine.  But the chain doesn't want to slide over the front sprocket.  I just want to make sure before I take the sprocket off.
Thanks,
Kev
Offline Hope
  • How did I become an
  • SOHC member since '01
Re: Chain removal question
« Reply #1 on: April 02, 2008, 02:51:44 PM »
If you have it down to the frame, you may want to replace the front & rear sprokets and the chain.  In that case, cut the chain OR just take it all off.
When I put mine back on the road I replaced the chain & sprockets for GP.
kevio
« Reply #2 on: April 03, 2008, 08:32:49 AM »
Thanks for the reply.  What chain and sprockets did you go with?  This bike only has about 14k original miles on it.  After a good soaking the chain and sprocket should still be good.
Offline heffay
« Reply #3 on: April 03, 2008, 08:50:43 AM »
i recommend renthal sprockets... lighter and supposedly just as strong or stronger than the old and/or current steel ones.
what keeps me coming back is the price though.  and, no... i don't have to go back very often.   ;)
Offline Hope
« Reply #4 on: April 03, 2008, 09:21:17 AM »
I just go to the Honda dealership & get the chain and sprockets.  I think they had to order them from partsnmore or somewhere...
I don't know about your dealership, but when you order through them, you don't have to pay shipping.
For instance, if I ordered the chain and sprockets through an online company, I would have to pay shipping, but if I order it through the dealership, I don't have to pay shipping.
I get the standard sprockets that heffay mentioned.... I've never got the renthal sprockets.
kevio
« Reply #5 on: April 03, 2008, 11:42:26 AM »
Thanks guys.  It sounds like I need to remove the front sprocket.  One more question.  How do you unbend the washers that lock the nuts down on the rear sprocket?
Thanks,
Kev
Offline lordmoonpie
    • Moonpie
« Reply #6 on: April 03, 2008, 12:24:10 PM »
Large flat bladed screwdriver down between the tab washer and the bolt and either lever or lightly tap with a mallet....being careful not to scratch anything of course ;)
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
