Author Topic: Reuse Crush Washers?  (Read 9091 times)
Offline bozo4onion
« on: April 03, 2008, 08:21:04 AM »
Can I reuse the crush washers to reassemble the front brake lines and master? Honda dealer service says NO. Can I get these w/o ordering from Honda (they're out here). Auto part store? This could really slow me down.
Re: Reuse Crush Washers?
« Reply #1 on: April 03, 2008, 08:22:41 AM »
You could anneal them, not sure what they are made of though..
Offline sparty
  • I just play one on TV
    • Gallery
« Reply #2 on: April 03, 2008, 08:23:24 AM »
If you want leaks you can re-use them.  Otherwise NO is the answer.
Sparty
1972 CB750 K2 Cafe' Style
Offline mkramer1121
« Reply #3 on: April 03, 2008, 08:30:45 AM »
Take them with to an auto parts store, they should have some.  Murray's had the copper ones for the oil lines/ oil filter bolt on the 750, would probably have the brake line ones as well.
Offline hymodyne
« Reply #4 on: April 03, 2008, 08:32:42 AM »
Gotta go with new ones...
hym
« Reply #5 on: April 03, 2008, 08:41:21 AM »
I anneal fork drain washers all the time, in less time than I could pick up new ones, if they had them. takes about a minute..
I have reused brake ones, they either leak or seal.
Offline mystic_1
  • 1970 CB750K
« Reply #6 on: April 03, 2008, 08:49:33 AM »
I do believe that our bikes use "standard" 10mm x 1.25 banjo bolts, crush washers are widely available for these and should cost very little.  Any motorcycle shop or dealer should have 10mm crush washers on hand.
Don't re-use old ones.
mystic_1
- John Augustus Shedd
Offline bozo4onion
« Reply #7 on: April 03, 2008, 09:43:41 AM »
Thanks for the help. I ordered 10 from a CBX site. $3.50 for 10 w/$9.00 shipping. They are $2.00 EACH (bend over) here at the Honda shop. The wait is the prob. Now to expose my ignorance....what exactly is annealing. I've seen bike builders anneal before forming metal by simply heating the panel w/a torch. I guess I need to know how hot and how long. Thanks
Offline Jinxracing
  • It's hot shit, not
  • '70 CB750 K1
    • The Hairy Nickel
« Reply #8 on: April 03, 2008, 09:57:29 AM »
In simple terms, annealing is the process of softening metal. The process varies depending on the type of metal being worked with. Usually it involves heating the metal red-hot and then allowing it to cool. How hot you get it and how fast you cool it down are the determining factors as to what hardness of metal you'll end up with.
A web search will give you answers on specific metals and their hardening/annealing/tempering processes. If you really want to get into it Machinery's Handbook has an awful lot of specific information.
–Captain Horatio Hornblower
www.thehairynickel.com
Offline merc2dogs
« Reply #9 on: April 03, 2008, 09:59:59 AM »
 If they're copper, simply heating it works to anneal them, no special cool down process required, copper can be quenched in water to anneal. With most other metals you need to heat then let it cool slowly, not quenched in anything. Some types of steel need to cool down over a day or better to be annealed.
 annealing temps are -normally- about half the melting temp of the material, but for practical purposes, if it glows even a little bit when the heat's removed it's warm enough
  You often see people welding a bracket or something, then dunking it in water to cool it off quick, and wonder why the bracket fails so often. quick cooling hardens the metal and canm cause it to fail after a few flexes.
Ken.
Offline Jinxracing
  • '70 CB750 K1
    • The Hairy Nickel
« Reply #10 on: April 03, 2008, 10:08:17 AM »
+1 !!!
One other quickie rule of thumb, when you're heating steel to harden or anneal it, the temperature that you want to hit before quenching or burying in sand is the same temperature that the steel loses its magnetic properties. So, you can stick a magnet to the steel being heated (not a rubberized fridge magnet unless you're feeling dangerous) and as soon as the magnet falls off, dunk it or bury it!
Offline bozo4onion
« Reply #11 on: April 03, 2008, 10:48:37 AM »
Hey thanks again. You guys are great. The Honda shop has 4 washers in stock and I may try and end my annealing virginity and torch the remaining 2 old ones. Kinda red and into water right? Strange how the manual (clymer) warns you about stuff like not pulling the brake lever with the caliper off but doesn't warn not to reuse the crush washers.
Offline mystic_1
  • 1970 CB750K
« Reply #12 on: April 03, 2008, 10:57:59 AM »
No, kinda red and then allow to cool slowly.  Bunging them into water would harden them, opposite of what you want to do.
mystic_1
Offline Jinxracing
  • '70 CB750 K1
    • The Hairy Nickel
« Reply #13 on: April 03, 2008, 11:22:07 AM »
True with steel, not with copper. According to a whole lot of online sources, copper should be heated and then quenched in water to anneal. Of course, if in doubt try it out!
Offline mystic_1
  • 1970 CB750K
« Reply #14 on: April 03, 2008, 11:52:21 AM »
Not doubting you one bit, just not sure now what the stock crush-washers are made of?  Are they copper?  If so they must be plated or somethings, as all the ones I've seen are silver in color.
mystic_1
Offline Jinxracing
  • '70 CB750 K1
    • The Hairy Nickel
« Reply #15 on: April 03, 2008, 11:57:22 AM »
Your guess is as good as mine when it comes to actual material, alloy, etc.  ;D
As for my $.02 on the matter, I'd never re-use those crush washers, annealed or not; I can't see the benefit of cheaping-out on any part of the braking system.
Offline mystic_1
  • 1970 CB750K
« Reply #16 on: April 03, 2008, 12:01:57 PM »
I agree completely.  Safety issues aside, one drop of brake fluid in the wrong place can sure ruin your paint job's day.
mystic_1
Offline bozo4onion
« Reply #17 on: April 04, 2008, 08:03:37 AM »
Me2 I guess. I'll wait for the new ones. thanks again for the help. Next.........Assembly and bleeding. I hear it's easy w/no problems ever.  :D
« Reply #18 on: April 04, 2008, 08:15:23 AM »
I think they are either aluminum or copper & plated.
Moot point for my bike as I changed to braided lines  decades ago... braided lines without banjos..looks so much cleaner without them..
The only  benifet they have (that I can see) is they adjust radially..
 If you dont understand metal that is designed to be annealed you will fear it.
Do bike people really actually still  use brake fluid that can damage their paint ??? who knew...
« Last Edit: April 04, 2008, 08:18:15 AM by 754 »
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #19 on: April 04, 2008, 08:16:07 AM »
Yup, just like carb work, a breeze. ;)
Offline CrisPDuk
  • Christ on a bike! Me, an
« Reply #20 on: April 04, 2008, 08:31:08 AM »
Crush washers are generally made from either copper or aluminum.  You can usually reuse the aluminium ones if you're feeling cheap, but 9 times out of 10 the copper ones will leak especially under pressure applications.
For the Honda brake lines you should be able to source the correct washers from any hydraulics service agency. M10 or 3/8" is a very common size for agricultural and industrial plant.
1978 CB550 K3
1985 H100S
Offline moham
  • .fnord.
« Reply #21 on: April 04, 2008, 05:47:00 PM »
...or ignorant, as in my case, having just re-built the front cylinder, caliper etc and standing there scratching my head wondering how all that fluid stayed in the line and the bolt just held together with two metal washers ???...For my bike, the washers didn't look overly compressed or misshapen (78 750k) and I'm assuming now that they are aluminum or similar (surley not copper, to my untrained eye) and I'm hoping I don't need to re-do the job with fresh washers. Guess I will have to check it out...(thanks for the piggyback bozo4onion)
78 750K-The Ocho
74 550-The Cherry Picker
70 750K0 motor-Dick in a Box
Offline 333
  • Time for change
« Reply #22 on: April 04, 2008, 06:12:05 PM »
My rule of thumb in these cases is: High pressure like brakes or hydraulic clutch, use new.  The oil drain plug, reuse 2 or 3 times, and then replace with new.
Who has time to anneal?
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
« Reply #23 on: April 04, 2008, 06:45:35 PM »
This should go over like a lead balloon. I just replaced all four 17 year old brake hoses on my 91 Acura Legend with new stainless braided hoses I got off EBay for $50. You'd think they come with new crush washers. NOT. Acura had 5. Honda had 3. Drive all over for half a day. 8 X $3.50 each. Screw it. The old original ones (not copper) had never been disconnected it appeared. REUSED THEM. Tightened them a little snugger. Topped off the fluid. I'm keeping an eye out for potential leaks. Of course the car is quite a bit safer than the bike. The way I figured this is if it were that important the Acura dealer and Honda dealer would have carried 8. They weren't out of stock either. They told me they do not carry that many.
« Reply #24 on: April 04, 2008, 07:02:54 PM »
Like I said, annealing takes a minute...
 How long does it take to get them from a dealer??
 I am not saying you should re-use them  (but i have), but as I pointed out a lot of riders dont know how to anneal...
 So I am asking now, what do you do with the crush washer wen you change fork oil??
