Author Topic: What's the proper way to prepare steel clutch disks?  (Read 2090 times)
Offline Patrick
« on: April 05, 2008, 05:47:01 PM »
I found various postings and FAQs on how to tell if your steel clutch plates are warped, but nothing definitive about the best way to prepare them for reuse. Do I want to polish them so they don't bind on them friction plates to make finding neutral easier? Do I want to rough up the surface on them so they grab the fibers better? Is minor pitting from age a bad thing or does it help them grab better?
What's the best route to a smooth clutch that finds neutral easily but doesn't break loose at WOT?
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Re: What's the proper way to prepare steel clutch disks?
« Reply #1 on: April 05, 2008, 05:54:16 PM »
 I bead blast mine.
Offline Patrick
« Reply #2 on: April 05, 2008, 08:47:54 PM »
What texture does bead blasting leave on the surface, Mike? I don't have a bead blaster. I'm just wondering if there's a way to replicate the finish without paying someone to do it.
Thanks.
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #3 on: April 05, 2008, 09:22:56 PM »
I bead blast mine.
I sanded mine today with 150 grit sand paper laid on a plate of glass to make it nice and flat. Gave them a nice even finish and took the glaze off. Also highlights any warpage.
Do you mean "glass" beads Mike? I might give that a try since I have a bit of time before I'm at putting the clutch together on mine. I don't want a weak clutch  ;)
 Matt.
Gallery at:
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #4 on: April 06, 2008, 10:20:14 AM »
bump.
Gallery at:
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #5 on: April 06, 2008, 03:46:45 PM »
According to wikipedia...
"Bead blasting is the process of removing surface deposits by applying fine glass beads at a low pressure without damaging the surface"
I learn something every day  :)
I'm gonna go ahead and bead blast my clutch plates before I put them in.
 Cheers, Matt.
Gallery at:
Offline Tower
  • Only at conception could I have been called a
  • My personal time machine: 1973 CB750K3
« Reply #6 on: April 06, 2008, 11:15:54 PM »
Glass plate and 150grit sandpaper are fine for removing warpage.  The final step should be 300 - 400 grit in a "spoke" direction.  Just enough to leave fine scratches, but not to remove a huge amount of material.
« Reply #7 on: April 07, 2008, 04:56:36 AM »
Thanks.
Patrick
Bead blasting raises the surface slighty (.0001/.00015)./ It blows all the contaminates out of the plates. Honda bead blasted the brake rotors of all their American Supersport bikes after races for the same reason.
Offline .RJ
  • homebase in your airspace
« Reply #8 on: April 07, 2008, 05:59:00 AM »
I do the same on my bikes before installing new pads.
Offline lordmoonpie
    • Moonpie
« Reply #9 on: April 07, 2008, 06:54:05 AM »
If it's warped, I junk them for the sake of the cost of a new one. If it just needs claening up - scotchbrite and elbow grease work nicely  ;)
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline Tower
« Reply #10 on: April 07, 2008, 08:40:35 AM »
MRieck, I didn't realize that bead blasting placed a 10 to 15-micron finish on the steels.  Are you certain of the decimal place?  That's quite a shiny finish compared to, say 800 grit paper (0.00125).  Smoother by about a factor of 10.
I've always used 400 grit thinking that its a little "better" i.e. grippier, than the original finish.
