Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
I'm in the middle of removing my oil seals too. When I looked at the bike and tried to figure out how to pull them off I figured that all I had to do was pull the clips and work out the seals...but apparently you have to remove the bottom from the fork tube by removing the allen bolt in the bottom of the forks. Did you do this?
